Hello,
Im trying to sublimate thin (0.5mm) aluminium sheets but i get a weird result.
The sheet looks dirty/blurry after sublimation. This happens even if i just use a blank paper with no print.
Any ideas why this is happening? Is it moisture or heat/pressure issue? See the photos below.
Thanks in advance
* Yes i have removed the protective film.
** This happens with any combination of temp/time setting
