User Tag List
Similar Threads
  1. Cold spots on mug press - light patches at edges
    By Cd1986 in forum Mug Presses & Ovens
    Last Post: 15-01-2014, 12:48 PM
  2. SENKO CAP PRESS plus plate press and newstar 40 vinyl plotter cutter
    By letsgo in forum Buy It, Sell it, Give it away!
    Last Post: 13-10-2012, 11:07 AM
  3. Anyone else using a mug press that you put the mugs in cold?
    By CarArtz Dave in forum Mug Presses & Ovens
    Last Post: 09-10-2012, 08:48 AM
  4. plate press - latte press- vinyl cutter wanted
    By Mattie in forum Buy It, Sell it, Give it away!
    Last Post: 30-12-2011, 07:01 PM
  5. Cool spots on heat plate
    By gadgetsboy in forum Heat Presses
    Last Post: 01-11-2010, 11:58 AM
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Member Printcess Jen's Avatar
    Join Date
    Dec 2012
    Location
    Essex
    Posts
    32
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Testing heat press/plate for cold spots
    Hi, does anyone have any advice on testing my heat press plate for cold spots. I have a swing away press and the plate does not look completely flat, it looks like very light indentations that go in slightly. Hope thats makes sense.
    Haven't purchased a temp gauge yet, thought i'd ask for advice first
    Any advice appreciated.
  2. #2
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,432
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    I use the infra red thermometers and they work a treat, £10 should get you one off eBay.
  3. #3
    Join Date
    Dec 2012
    Location
    Essex
    Posts
    32
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ah thats good to know, thanks Justin, will give it a go!
  4. #4
    Member
    Join Date
    Nov 2009
    Location
    south
    Posts
    885
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What justin said
    regards
    Tony
    -long gone, sadly.
    - currently dormant, explanaition in linkedin profile
  5. #5
    Senior Member logobear's Avatar
    Join Date
    Feb 2010
    Location
    Newcastle upon tyne. UK
    Posts
    1,667
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    how accurate do the thermometers need to be?
    maplin sell one for about £25 that is +/- 3c but the £55 one is +/- .25c so loads better and laser accurate too.....
  6. #6
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,416
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    I have an interesting take on one of these...
    I recently took delivery of a heat press for testing. The press came from TMT and is a new clam shell with a slide out platen. A review will come shortly but one thing I did notice was that the temp was set for 165 degrees yet my thermometer was reading over 180. I spoke with Adam at TMT and he said that this was fine. He said that although digital thermometers are okay, to get a proper reading then you need to get temperature strips and put them under the presses press.
    Logobear, I think the £25.00 will be more than good enough. Think of it like this, if you have a bit of vinyl to press on a garment which is recommended at 180 degress for 15 seconds. It will press just as well using 185 degrees at 15 seconds. so +/- 3 is more than accurate enough I think.
    S>
  7. #7
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,432
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    Quote Originally Posted by socialgiraffe View Post
    Surprised to hear that, I didn't think the strips would be as good but I'm prepared to stand corrected :-) I used a very high quality laser therm and tbh not much difference to my £10 unit which seems very accurate.
  8. #8
    Senior Member
    Join Date
    May 2012
    Location
    Plymouth
    Posts
    1,900
    Downloads
    0
    Uploads
    0
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    We make the assumption that the garment and the medium we are using are consistent, they are not. They will both vary from batch to batch. Lets pick 180 degrees for 180 secs .... is 190 for 190 going to be a problem ... no ..... what about 170 for 170.... probably not. There is a degree of latitude. Consistent heat and pressure across the platen is more relevant. This is where the strips score over a thermometer. The strips are giving a reading indicative of the effects of both.
    I add that this is as I see things in my little world. Your world may be different.
    Janners
  9. #9
    Join Date
    Feb 2010
    Location
    Posts
    1,667
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    some media is not as critical as others, wow 7.2 (the old one) was super fussy, but i think the issue of uneven heat will make a difference, just like uneven pressure !
    the paper temperature strips are VERY accurate, half a c i think.....
  10. #10
    Join Date
    Dec 2012
    Location
    Essex
    Posts
    32
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Temp strips sound like a good try too. I do have a feeling that some parts outside of the central part of the plate are not hearing efficiently. However I hope to be purchasing a new press in the near future. I'm thinking a nice clam shell.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
