Join our Premium Membership now and save with Xpres, Ink Express and more! Just £10 per year.....Click the Membership link above.....
User Tag List
Similar Threads
  1. Mug press or 3d vacuum machine?
    By Cd1986 in forum Mug Presses & Ovens
    Last Post: 19-05-2016, 07:59 PM
  2. MUG HELP!!!!!! 3D Vacuum Sublimation Machine
    By Hollyanna in forum Mug Presses & Ovens
    Last Post: 19-05-2016, 07:54 PM
  3. 3D Mini Vacuum Machine
    By dowfer in forum 3D Sublimation
    Last Post: 21-02-2015, 02:45 PM
  4. 3d sublimation vacuum machine any advice
    By jennywren in forum 3D Sublimation
    Last Post: 17-10-2014, 08:48 PM
  5. Chinese vacuum machine - which model to get?
    By magda in forum 3D Sublimation
    Last Post: 22-07-2014, 12:09 PM
Results 1 to 3 of 3
  1. #1
    Junior Member
    Join Date
    Feb 2015
    Location
    lithuania
    Posts
    2
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Vacuum heat machine unresponsive buttons issue
    hello.
    At the moment im facing a problem with vacuum machine from best sub. when i turn on 3D SUBLIMATION HEAT MACHIEN (ST 3042) buttons and touch panell is not responding to touching and pushing buttons. only one half of panel doesent work (buttons: ,,POWER'', ,,TIME SETTING'', ,,TEMPERATURE'', ,,-'') the rest of the buttons works well. i want to ask if someone have faced this problem and what solutions it may have ? do i need to change control panel or the main board ? where to buy those spare parts if the fault are in it ?
    there is a photo of which buttons does not responds to pushing/tauching.
    Attached Images Attached Images
  2. #2
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,415
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    They are horrible buttons (I have the same machine). I have found a very small indentation somewhere on each button and that works for me. If that does not work I would recommend you taking it to an electrician and ask them to replace with proper switches
  3. #3
    Junior Member
    Join Date
    Feb 2015
    Location
    lithuania
    Posts
    2
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    https://www.youtube.com/watch?v=3loj...ature=youtu.be
    there is a video, we cant understand what is wrong with that hell machine.. anyone faced somethong simmillar ?
    Issue: Control panel is working not properly.
    1.When machine is turned on its buttons only responds to these buttons which are on right side, only after pressing all of them(TIMING, VACUUM, HEATING) other side buttons starts to respond. i always need to perform these actions in order to be able to press any of POWER, TIME SETTING, TEMPERATURE,+/- buttons.
    2.Usually when turned on SUBLIMATION HEAT PRESS MACHINE is not responding AT ALL to any pushing of the buttons.
    3.In order to set the temperature it automaticaly drops to the lowest temperature. to button (+) it reacts as to button (-) meaning that the temperature or timing only can be minused.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
