User Tag List
Similar Threads
  1. Smash-proof mug boxes from Subli Blanks
    By anniecov in forum General Dye-Sub Chit Chat
    Last Post: 24-10-2016, 07:14 PM
  2. Smash Proof Boxes, Really???
    By Designandgift in forum General Dye-Sub Chit Chat
    Last Post: 27-11-2015, 06:48 AM
  3. Acetate and smash proof mug boxes.
    By galerion in forum General Dye-Sub Chit Chat
    Last Post: 13-06-2014, 11:54 PM
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
  1. #11
    Senior Member
    Join Date
    Jun 2014
    Location
    Devon
    Posts
    1,051
    Downloads
    2
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thats no good then......... all mine are 8cm.
  2. #12
    Member
    Join Date
    Jun 2016
    Location
    Scotland
    Posts
    70
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    @ArferMo,
    These are bigger (internal size 9cm x 12 cm)
    https://www.amazon.co.uk/dp/B00U1IGH...3245199&sr=8-8
  3. #13
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,397
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by UK Printed Mugs View Post
    All our mugs are 8cm and fit perfectly into the box. As I say we have started using these recently from Longforte and not one issue yet.
    Inner width on my boxes are 79mm. Xpres mugs are 81-82mm diameter subject to variation of a couple of mm. So the boxes would need to be at least 5mm bigger. OK, they fit with a bulge, but not the safest, anything that touches the wall of a parcel will get smashed.
  4. #14
    Premium Member UK Printed Mugs's Avatar
    Join Date
    Aug 2014
    Location
    Poole, Dorset
    Posts
    2,158
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    All we can go on is experience and having used over 100 of these boxes on listawood and xpres 10oz mugs recently then we have not had one smash. We see it as an advantage that the mugs fit so snug (touch the sides) because it is the movement of a mug inside the box which can cause major problems such as handle hitting the side and breaking off.
  5. #15
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,397
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    "Fragile items shouldn't touch either each other, or the side of the container."
    https://personal.help.royalmail.com/...ckaging-advice
    When Longforte tell you to insert the mug in as pictured. This is the wrong way! The weakest part of the mug is the handle and it's placed against the weakest part of the box. Place the handle at the front where it has an extra wall of cardboard protecting it.
    Attached Images Attached Images
  6. #16
    Longforte
    Guest
    Hi ArferMo,
    Thanks for your comment. Many of the customers of our 11oz Durham Mugs use these boxes and all of our mugs have an 8cm diameter.
    If you're not convinced just send us your address and we'll pop over a free sample to you so you can try them out yourself.
    Kind regards,
    Jay
  7. #17
    Member
    Join Date
    Mar 2015
    Location
    Oxfordshire
    Posts
    537
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So these are out of stock with Longforte at the moment, where else can they be had from? I liked the white over the usual brown though I can't be too fussy as I've none here!
  8. #18
    Join Date
    Aug 2014
    Location
    Poole, Dorset
    Posts
    2,158
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
  9. #19
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,397
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    I'm using the white boxes from subliblanks. Good fit and nice and white. Only downfall is that they shed a lot more dust than other boxes I've tried.
  10. #20
    Banned
    Join Date
    Dec 2016
    Location
    manglore
    Posts
    21
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi,
    thanks for sharing the information here.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
