if you use the menu on the printer to find out what the ip address is, (something like 192.168.1.44 as mine is setup). You can then test the communication from typing that number into your web browser. It should show you a status display telling you about the printer. If not it's not communicating. That's a good place to start unless you haven't tried turning it off and on again already ;-)
Alex.
