Join our Premium Membership now and save with Xpres, Ink Express and more! Just £10 per year.....Click the Membership link above.....
User Tag List
Similar Threads
  1. What am I doing wrong?!
    By Anth1981 in forum Mug Presses & Ovens
    Last Post: 15-12-2015, 08:33 PM
  2. what did i do wrong?????
    By fiona in forum Printing Problems/Issues
    Last Post: 23-06-2015, 11:45 AM
  3. What am I doing wrong
    By Miffmiss in forum Mug Presses & Ovens
    Last Post: 21-02-2015, 06:06 PM
  4. can someone tell me where im going wrong
    By george in forum Printing Problems/Issues
    Last Post: 08-06-2014, 09:33 AM
  5. I must be doing something wrong.
    By Earl Smith in forum Take a Break
    Last Post: 28-02-2014, 11:48 AM
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: Something wrong
  1. #11
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,433
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    First off, you're wasting your time without first installing an ICC profile and MAKING YOUR GRAPHICS SOFTWARE USE THE PROFILE to print. This is a very important first step. You must switch off colour management in your printer driver and let your graphics software manage colours via the ICC.
  2. #12
    Senior Member logobear's Avatar
    Join Date
    Feb 2010
    Location
    Newcastle upon tyne. UK
    Posts
    1,667
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    the F instead of C is a very destinct possibility !
  3. #13
    Junior Member
    Join Date
    Oct 2018
    Location
    clacton on sea
    Posts
    13
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    sorry but I don't really get that F instead of C what did you mean ?
  4. #14
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,433
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Is your press reading in degrees Fahrenheit or Celsius? It's a common mistake to be sublimating at way too low a temperature, 180 deg F, instead of 180 deg C.
  5. #15
    Junior Member
    Join Date
    Oct 2018
    Location
    clacton on sea
    Posts
    13
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    it is reading at 180 Celsius I have had delivered today some samples of dyes sub printed already tried and all working good with press not a problem.So there is a problem with ink or printer I think I have asked cie for ICC but they have got funny with me a bit said that I don't really need ICC to print and do sublimation.No idea if I need to get new ink or what else to do.
  6. #16
    Junior Member
    Join Date
    Oct 2018
    Location
    clacton on sea
    Posts
    13
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I do have to diffrent type of paper. one is from Ink Express sublimation shrapnels 120g ,other one is from CIE.When pressed image is exactly the same yellow on both papers.I I have changed ink ( I did get that with printer so it is second hand ) I have flushed heads as well.
  7. #17
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,433
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Quote Originally Posted by jack73 View Post
    I can't understand why CIE would say you don't need an ICC profile for sub-printing with their inks and a Ricoh 3110 printer. I've always found communications with CIE to be excellent.
    Saying that, since I use the same inks, paper and printer as you, I can PM you a link to download a CIE profile (for your MacOs) and see if that makes a difference. I don't print with Inkscape though so you'll have to find out how to use an ICC with that software.
    The only other thing I can think of that may be causing your issue is that you haven't flushed the old inks right through and the new inks aren't reaching the print heads yet. It takes a LOT of ink to refill those ink lines.
  8. #18
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,418
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    Is it Ink Express Subli Sharp paper? Are you saying the transfer print is yellow or only yellow is transferring?
    No matter what the paper is if it's just printing yellow the fault is with your printer. if the profile was wrong, settings wrong etc. it would still be colour, all be it the wrong colours. Just yellow leads me to thin CMK are blocked. Can you post pic of nozzle check.
    if you had old non subli ink in that printer it all needs flushing out, you can';t just add carts and it will work through, it will take forever.
    Other than the cotton t-shirt, what else have you tried pressing onto?
  9. #19
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,433
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    @jack73 I have PM'd you with an ICC profile and instructions.
  10. #20
    Junior Member
    Join Date
    Oct 2018
    Location
    clacton on sea
    Posts
    13
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Just to let you all know finally all is working how it’s should with all of your help sonone day we will have cold bear lol so there they are light not good and still need to learn a lot about it all how to place and all of that but getting there .
    Attached Images Attached Images
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
