Join our Premium Membership now and save with Xpres, Ink Express and more! Just £10 per year.....Click the Membership link above.....
User Tag List
Similar Threads
  1. Dell PowerEdge 850 Web Server for photoshop cs6?
    By FutureProject in forum Hardware
    Last Post: 01-02-2015, 03:34 PM
  2. print and cut near sussex needed
    By ptholt in forum Member to Member Offers/Requests
    Last Post: 19-06-2014, 02:13 PM
  3. Print and Cut on vinyl price needed
    By JackB in forum Member to Member Offers/Requests
    Last Post: 22-03-2013, 12:45 PM
  4. Migration to new server is done!
    By Paul in forum Pauls Photo Mug Templates
    Last Post: 28-01-2013, 12:25 AM
Results 1 to 7 of 7
  1. #1
    Premium Member UK Printed Mugs's Avatar
    Join Date
    Aug 2014
    Location
    Poole, Dorset
    Posts
    2,154
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Dedicated Print Server - is one needed?
    We currently have about 12 printers connected by wireless / usb directly to one laptop and or via network cable to router.
    Currently one laptop is used to produce artwork and send jobs direct to relevant printer.
    Is there a better way of managing this especially for future proofing whereby we might want another computer to send jobs to a printer?
    We are moving to a better premise soon and be good chance to put house in order.
  2. #2
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    4,302
    Downloads
    0
    Uploads
    0
    Mentioned
    6 Post(s)
    Tagged
    3 Thread(s)
    We tried using one PC essentially as the server, and using it to share the printers, but although this meant we could print to the printers from any computer, it had the downside of taking longer to print, as the print file was spooled and sent from user's computer to server, which would then respool and send to the printer.
    Not revisited it since, now we have one computer with the printers attached via USB and not shared, with the print spool separate on an internal SSD drive, but also set to keep spooled files, so for common designs we can reprint direct from the print queue, not having to reload into Photoshop
    (The SSD drive only has the print spool/queues, Windows swap file, Photoshop scratch disc, and Adobe Bridge cache on it)
  3. The Following User Says Thank You to pisquee For This Useful Post:
    UK Printed Mugs (19-12-2018)
  4. #3
    Join Date
    Aug 2014
    Location
    Poole, Dorset
    Posts
    2,154
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    What useful information thank you. Is it Adobe Bridge that would allow print jobs to be resent to printer without needing say Photoshop again?
  5. #4
    Senior Member logobear's Avatar
    Join Date
    Feb 2010
    Location
    Newcastle upon tyne. UK
    Posts
    1,667
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    We are the complete opposite, with multiple computers all printing to common printers.
    Nearly all printers are ethernet connected so easy to hot desk....
    Can you set up your printers as network printers instead of local with sharing?
  6. #5
    Premium Member
    Join Date
    Nov 2011
    Location
    Posts
    4,302
    Downloads
    0
    Uploads
    0
    Mentioned
    6 Post(s)
    Tagged
    3 Thread(s)
    No, not from Bridge - from the print queue window itself, in printer settings you can select to keep print jobs, so when a job finishes it stays held in the queue, so you can right click it and select Restart ... we have one main sublimation printer (wide format) and have multiple print queues set up for it - so one for cushions, one for lampshades, etc ... so each standard design is just held in the queue and can be reprinted without having to load a file into any programme, just using the Windows print driver system.
  7. #6
    Join Date
    Aug 2014
    Location
    Poole, Dorset
    Posts
    2,154
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Ooooo thank you. Can I ask should we be using Adobe Bridge? I need to read up more about it but does it put all your design resources on the cloud (external) or is it for organising artwork files locally?
  8. #7
    Premium Member
    Join Date
    Nov 2011
    Location
    Posts
    4,302
    Downloads
    0
    Uploads
    0
    Mentioned
    6 Post(s)
    Tagged
    3 Thread(s)
    Adobe Bridge can be just a file browser, but can be used for batch processing files using actions you set up in Photoshop - being able to print from it directly is missing though
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
