Join our Premium Membership now and save with Xpres, Ink Express and more! Just £10 per year.....Click the Membership link above.....
User Tag List
Similar Threads
  1. Ricoh SG 3110DN ink low
    By aidy999 in forum Printing Problems/Issues
    Last Post: 14-01-2019, 12:35 PM
  2. Ricoh 3110DN
    By Alicef in forum Printers
    Last Post: 09-02-2018, 09:36 PM
  3. ricoh 3110dn
    By paul 44 in forum Printers
    Last Post: 30-08-2016, 03:47 PM
  4. SG 3110dn installation problem
    By pamela in forum Printers
    Last Post: 03-04-2016, 09:35 AM
  5. ricoh 3110dn
    By guarddog14 in forum Printers
    Last Post: 18-03-2016, 10:43 AM
Results 1 to 7 of 7
  1. #1
    Junior Member
    Join Date
    Feb 2019
    Location
    Larne
    Posts
    4
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ricoh 3110dn problem
    New member here but I have been subbing for quite some time now with my Ricoh and two Epson Ecotank printers.
    My Ricoh has been playing up for a couple of weeks now and I have again downloaded Powerdriver again, cleaned the
    heads and still the problem persists.
    I have attached a template that I use quite often and you will see the problem on the border and I can usually hear when
    the fault occurs in that you would think that the printer is taking a 'breather' for a split second and then continues on it's way.
    Any suggestions would be gratefully received.
    Attached Images Attached Images
  2. #2
    Senior Member Ian M's Avatar
    Join Date
    Jun 2010
    Location
    Bradford
    Posts
    1,560
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  3. #3
    Junior Member
    Join Date
    Feb 2019
    Location
    Larne
    Posts
    4
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sincere thanks for the link, did exactly as instructed but sadly I still have the same fault.
  4. #4
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,415
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    When the fault starts occurring have you tried a different paper?
    Just thinking of ways to eliminate/isolate the issue.
  5. #5
    Junior Member
    Join Date
    Feb 2019
    Location
    Larne
    Posts
    4
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tried 3 different papers and all show the same fault.
    There is always is a clicking sound halfway through the printing process so I knew to expect the problem when the printing finished
    so I assumed that there was a mechanical fault rather than an ink or a paper fault
    Nozzle checks have always been OK and head alignment OK but this afternoon I did 2 head flushes and I have noticed a considerable improvement
    so I am letting her rest now and I will look at her again in the morning.
  6. #6
    Senior Member
    Join Date
    Nov 2009
    Location
    Newcastle upon Tyne
    Posts
    2,937
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I sometimes have this problem - I've put it down to the paper being too cold or damp to feed properly, so it mis-feeds halfway through the print.
    I work from my garage, so in the mornings I give the printer a gentle blow with a heater, into the paper feeds, this normally does the trick!
    I may just hit lucky with this, but it works for me
  7. #7
    Junior Member
    Join Date
    Feb 2019
    Location
    Larne
    Posts
    4
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Certainly worth a try John - the temperature in my office is 14 degrees these mornings (16 degrees now) so thank you for your reply.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
