User Tag List
Andysam26467, GoonerGary, Jason, Justin
Similar Threads
  1. halogen oven vs Sublimation vacuum oven
    By smiley_mug in forum Mug Presses & Ovens
    Last Post: 21-08-2023, 02:21 PM
  2. One for the bn20 owners...
    By scotty44 in forum Misc. Printing
    Last Post: 22-07-2016, 10:52 AM
  3. Ricoh owners I need a little help!
    By scotty44 in forum General Dye-Sub Chit Chat
    Last Post: 10-03-2015, 11:49 AM
  4. For DTG owners only
    By socialgiraffe in forum General Dye-Sub Chit Chat
    Last Post: 28-08-2014, 10:00 AM
  5. Convection oven
    By thepetographer in forum Mug Presses & Ovens
    Last Post: 30-09-2012, 11:03 AM
Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 101
  1. #41
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,397
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Just a quick update. At the start, I mentioned I was getting faded patches. I'm blaming this on not having the transfer on super tight. It wasn't so much of an issue before with the mug presses, since they clamp the transfer tighter. I also reject mugs which have little dents or rippled coating, so this has eliminated any patchy printing.
    Transfers are cut up to the height of the mug, I haven't noticed any gas staining.
    All 10oz mugs, regardless of quantity, including enamel mugs and aluminium water bottles are put in at 20 mins at 160 degrees as previously mentioned.
  2. #42
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,436
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    I've also changed to 160/20 now regardless of quantity and working a treat :-)
  3. #43
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,416
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Ditto and although marginally slower per hour, I much prefer it so cheers Gooner :-)
    Stay tuned as I am working on another MAJOR cost cutting idea :-)
  4. The Following 2 Users Say Thank You to socialgiraffe For This Useful Post:
    GoonerGary (01-05-2019), Justin (01-05-2019)
  5. #44
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,397
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    So what's the most amount of mugs we can pack in? I've only put a maximum of 18 mugs into the oven with good results.
  6. #45
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,436
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    I've done 24 with no problems, pretty sure you'd get more but I'm happy at that :-)
  7. #46
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,416
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Pretty sure 24 is the maximum (12 per tray), but your trays get pretty shagged quite quickly as the weight is too much.
    However, I think with a bit of modification it might hold 36. Although that’s a lot of mugs to spunk if it doesn’t work LOL.
  8. #47
    Member
    Join Date
    Jul 2018
    Location
    Sheffield
    Posts
    154
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Justin View Post
    So, chuck mug in (and start timer) when oven gets to 160?
    Going to give this a try if I get time today. - Which orientation do you recommend for these timings? (I've seen vids varying between stood up, mug upside down and mug on it's side (turned halfway through).
  9. #48
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,397
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    I place mine with mug base on the tray with 1cm or so distance between each mug. Nine on each tray and they don't move until 20 mins is up. I'm using the cheapo green wraps.
    Enamel mugs, I place upside down because of the different style of silicone wrap.
  10. The Following User Says Thank You to GoonerGary For This Useful Post:
    Baldy (21-05-2019)
  11. #49
    Member
    Join Date
    Jul 2018
    Location
    Sheffield
    Posts
    154
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Cheers Gooner. Very helpful info. Fingers crossed
  12. #50
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,397
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    I've switched to Listawood Duraglaze mugs and had to increase the time to 22 mins and 160 degrees C. Although I find that I get faded and undercooked patches when I try to pack 18 mugs onto the two trays.
    I also discovered that you can leave the wraps on until the mugs are cold before removing the transfer, so no overcooking and no burning your hand trying to get the transfers off.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
