Hey all,
Wondering if I can get some advice?
I got a new set up from InxExperts ET-2711 bundle with inks and ICC. I installed it all with no problems (glad it was so easy)
I also bought a ST-3042 3D SUBLIMATION Vacuum Oven Heat Press
Whilst setting this us was a bit of a challenge I did get there in the end.
Excited to try out the new press I was dissapointed with the final results. Although the printing seemed crisp and clear the final result wasn't so.
I tried @ 180 degrees for 4 minutes, with hardly any print showing.
I tried @ 190 degrees for 7 minutes with some print showing
I tried @ 190 degrees for 9 minutes with the attached results showing.
for the Coffee mug it should all be jet black, for the TMD the TMD should be jet black and the next word grey.
As you can see the black is faded, on the yellow mug it is brighter at the bottom than the top.
Not sure where I am going wrong however any advise would be gratefully received.
