User Tag List
Similar Threads
  1. oven mug wraps
    By mrs maggot in forum General Dye-Sub Chit Chat
    Last Post: 29-05-2012, 11:22 AM
  2. Epson 1400 with sublimation CISS mug oven wraps and blanks
    By Relativeportraits in forum Buy It, Sell it, Give it away!
    Last Post: 09-03-2012, 01:10 PM
  3. Using wraps in domestic oven
    By Renniwano in forum Mug Presses & Ovens
    Last Post: 29-10-2011, 07:01 PM
  4. Mug Oven & Wraps *** NOW SOLD ***
    By accdave in forum Buy It, Sell it, Give it away!
    Last Post: 06-03-2011, 01:47 PM
  5. Do you NEED cactus wraps for a mug oven?
    By cath in forum Mug Presses & Ovens
    Last Post: 25-08-2010, 10:40 PM
Results 1 to 2 of 2
  1. #1
    Premium Member UK Printed Mugs's Avatar
    Join Date
    Aug 2014
    Location
    Poole, Dorset
    Posts
    2,158
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Sublimation Oven and 42 Mug Wraps
    SOLD
    For more info please see:
    https://www.ebay.co.uk/itm/264773401723
    It comes with over 42 mug wraps which alone are worth over £300. Not sure what I am thinking here :-)
    If you offer over £165 then it will automatically accept.
    Note that we only ever used this for the oven, which works perfectly, but unsure if the vacuum side works correctly so please buy if you only want this for the oven side of things and the vacuum would be a bonus if works!
  2. #2
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,416
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Hi Olly
    Not particularly interested as I already have one, however its really easy to test if the vacuum works. Just turn the machine on and press vacuum. If you hear the pump then put your finger over the small threaded hole in the bottom corner of the machine, if you can feel the tip of your finger being sucked in and the vacuum pump changes to a different noise then its probably working.
    Imagine a vacuum cleaner that all of a sudden becomes blocked and how it changes
  3. The Following User Says Thank You to socialgiraffe For This Useful Post:
    UK Printed Mugs (23-06-2020)
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
