Join our Premium Membership now and save with Xpres, Ink Express and more! Just £10 per year.....Click the Membership link above.....
User Tag List
Similar Threads
  1. Start up kit arrived!
    By melridd in forum Mug Presses & Ovens
    Last Post: 08-03-2015, 11:42 AM
  2. New toys arrived!!
    By smo in forum Heat Presses
    Last Post: 28-04-2013, 02:03 PM
  3. cutter arrived and set up.. after fix!
    By ssp in forum Vinyl Cutters
    Last Post: 17-04-2013, 02:01 PM
  4. My printer has arrived!
    By twinsgran in forum Printers
    Last Post: 29-11-2012, 06:49 PM
  5. My Ricoh has arrived!!!
    By Mark Clayton in forum Printers
    Last Post: 11-01-2012, 06:19 AM
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
  1. #11
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,418
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    Thanks Reg, just done that. I had it a bit far out, it now hardly shows past the end of the holder but is cutting fine. What is the purpose of the spring loaded push section at the top of the holder? The bit that moves the needle further.
  2. #12
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    I use that when some vinyl dust is stuck there so I think is for cleaning the knife :)
    <-- How To Print Stuff BLOG
  3. #13
    Member Reg's Avatar
    Join Date
    Dec 2009
    Location
    Fareham Hampshire
    Posts
    301
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think it's a shock absorber the pen holder has the same set up.
  4. #14
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,418
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    Not sure I've got this set up right, I lowered the pressure to 10 and it still works as well. It's not going through the backing but surely it shouldn't still cut at such a low setting?
  5. #15
    Member Reg's Avatar
    Join Date
    Dec 2009
    Location
    Fareham Hampshire
    Posts
    301
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just tested my cutter at 10 and it dose not get through the vinyl I think you need to back the blade off a bit more.
  6. #16
    Member
    Join Date
    May 2010
    Location
    Westbury, Wiltshire
    Posts
    173
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've just received the same cutter too!
    Using signblazer, I've written some simple text and sent to the cutter, allbeit using the pen rather than the blade.
    I've been reading on this and other forums about the need to design in Corel Draw (I have version 10), export to .EPS, import into signblazer and cut. Simple! Well.... I have no experience with Corel Draw so must be doing something wrong. In Cdraw I've imported a clipart image of a deer (it looks like a stag for a stag-do shirt!). It's a colour clipart. I've exported to EPS, imported into Signblazer but it's still a solid coloured image. Will Signblazer cut the outline, or do I need to do somthing in Cdraw first (Vectorise? - whatever that is).
    Any help gratefully received.
    Barry
  7. #17
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,418
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    You can cut direct from Coreldraw with this cutter, I have the plug in. Not sure if you bought it from the same seller as me but I no longer have anything to do with him as the service was so poor it was beyond belief.
  8. #18
    Member
    Join Date
    May 2010
    Location
    Westbury, Wiltshire
    Posts
    173
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Justin. I got this from the same eBay seller as Paul. Support has been great so far (I was on the phone to him at 11:30 last night!!).
    I think I may have the plug-in on one of the CDs which the cutter came with. I will take a look.
    As for cutting from Corel, do I need to do anything with my "stag" clipart image?
  9. #19
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,418
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    OK, best of luck then. Support from this seller was excellent for me at first but soon turned bad. Maybe you'll have a good experience the same as Paul but personally I won't be recommending anyone buys from this seller.
  10. #20
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    How do you geting on with conour cutting on your cutter justin??
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
