User Tag List
Similar Threads
  1. Drilling Aluminium sheet ...
    By webtrekker in forum Hints & Tips
    Last Post: 23-11-2016, 08:41 AM
  2. 3D Sublimation Prints onto Silicon Sheet
    By PracticalRepair in forum Printing Problems/Issues
    Last Post: 14-09-2015, 01:22 PM
  3. Data sheet required for aluminium
    By Niki MM in forum Printing Problems/Issues
    Last Post: 08-10-2014, 12:46 PM
  4. Sublimation sticker sheet
    By confidential in forum General Dye-Sub Chit Chat
    Last Post: 20-05-2010, 08:02 PM
  5. Sublimation Aluminum Sheet?
    Last Post: 29-04-2010, 12:58 PM
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Junior Member
    Join Date
    Aug 2021
    Location
    Athens
    Posts
    9
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well… thats what i thought and thats why i started messing with the settings. This is moisture. The paper needs to dry for 5 minutes. Maybe more. I also reduced the ink density of my Epson Ecotank a bit. Now im able to get pretty good results with 185c and 60 seconds. No cloth or anything else. Although i can still see the marks that i mentioned first when i put the sheet under a light. They are not that visible though anymore. The sheets are from alibaba… Im looking for another supplier. Any suggestions? Also, are all aluminium sheets that easily scratched? Even a simple wipe leaves lines.
  2. #12
    Premium Member
    Join Date
    Jan 2016
    Location
    United Kingdom
    Posts
    41
    Downloads
    1
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I only use metal from sublimetals, and 185C 45seconds works great for any size, the large 20x30inch image and 16x24 image on sublimetals website are ones i have printed = paper on the bottom of press with print facing upwards metal on top with print side facing down - a mediumish pressure (although them big ones were done at 7bar pressure) and never have an issue.
  3. #13
    Junior Member
    Join Date
    Aug 2021
    Location
    Athens
    Posts
    9
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello,
    I will try to reduce the time although im pretty sure i read that longer time means more durability for the print. I will check sublimetals although after Brexit buying from UK businesses is too expensive.
    My press is 40x50 cm but it has no indicator for the pressure so im not sure if 7bar is a lot or not.
    Thanks for your comment!
  4. #14
    Premium Member
    Join Date
    Jan 2016
    Location
    United Kingdom
    Posts
    41
    Downloads
    1
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    7bar is very high pressure (around 100psi), on my stahls i generally user 6-7 on the pressure read out which is medium ish in my opinion. With import+vat etc etc i have very rarely noticed its much cheaper buying in from abroad myself.
  5. The Following User Says Thank You to whitprints For This Useful Post:
    kman21 (23-08-2021)
  6. #15
    Member
    Join Date
    Aug 2021
    Location
    doncaster
    Posts
    48
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Paul View Post
    ALWAYS USE DRY PAPER. AS WET INK WONT HELP YOU. IT WONT BE YOUR FRIEND AT ALL.
    i FORGOT TO MENTION THAT YOU DONT USE ANY CLOTH. AND PRESS IT UP SIDE DOWN. sO PAPER AT THE BOTTOM. LOW, VERY LOW PREASURE. !85C for 45sec as starting point.
    PS. sory about the caps
    could possible check my post to see if you know my issue
  7. #16
    Junior Member
    Join Date
    Feb 2013
    Location
    Hamilton
    Posts
    20
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My money would be on the paper being the issue.
    What type/brand are you using?
  8. #17
    Junior Member
    Join Date
    Aug 2021
    Location
    Athens
    Posts
    9
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi,
    I have used two different types of paper (Sublisplash-DyeSub). Same result.
    Actually i found posts describing this very same issue from 10 years ago so its pretty common.
    It is know as "orange peel" or "watermarks". It appears usually on the cheaper aluminium sheets with thinner coating.
    My understanding is that because of the thinner coating the paper is imprinted on it, leaving these marks.
    I could not find a solution. I have used a variety of settings combinations (heat-time-pressure) with no luck.
  9. #18
    Junior Member
    Join Date
    Feb 2013
    Location
    Hamilton
    Posts
    20
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    An easy way to test if it's the paper or not is to put a little water on a microfiber towel and rub it over the areas with the marks. If they come off or lighten, it's the paper.
    Some of the self branded xpres paper left these kinds of marks but was fixed by wiping over the area.
    Might be worth a shot and help narrow things down a bit more.
  10. #19
    Junior Member
    Join Date
    Aug 2021
    Location
    Athens
    Posts
    9
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nope it wont come off :(
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
