User Tag List
Similar Threads
  1. single presses or multi-presses for pressing 300 mugs?
    By Violetsub in forum Mug Presses & Ovens
    Last Post: 07-11-2017, 12:50 PM
  2. Mug ovens
    By cleverprintinguk in forum Mug Presses & Ovens
    Last Post: 03-02-2017, 12:00 PM
  3. Mug presses vs ovens
    By Deano82 in forum Mug Presses & Ovens
    Last Post: 12-10-2015, 11:30 AM
  4. Mug Ovens
    By booflegem in forum Mug Presses & Ovens
    Last Post: 22-11-2012, 02:03 PM
  5. Mug Ovens
    By Andrew in forum Mug Presses & Ovens
    Last Post: 19-03-2011, 07:29 PM
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
  1. #31
    Premium Member
    Join Date
    Oct 2015
    Location
    Lancashire, UK
    Posts
    253
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by JMugs View Post
    I ran a small oven that held six mugs for a while (9 would have been possible), so not quite the same scale. My studio was always cold in the winter so I used a second oven set at 40 degrees to preheat mugs, my random failures became very few. Bonus was I stopped making adjustments from winter to summer.
    This would illiminate the cold spots issue.
    Janners
    Can I ask how long you pre heated the mugs for?
  2. #32
    Junior Member
    Join Date
    May 2021
    Location
    Southampton
    Posts
    11
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gazfocus View Post
    even in a press I have to preheat especially on full prints
    you need to preheat long enought that the thick base on the mug is heated through... at these temps it's too cold to sub so can't over do it
    in my press I preheat at 100 degrees for about 3 minutes.. long enough that when I touch the base in the centre it's no longer cold
    Sent from my SM-G998B using Tapatalk
  3. #33
    Premium Member
    Join Date
    Oct 2015
    Location
    Lancashire, UK
    Posts
    253
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by rgsearley View Post
    I have to be honest, in the years that I’ve printed mugs (and we do hundreds a day), we’ve never pre heated a mug, ever.
    That being said, I wouldn’t discount it’s benefits and I will definitely give it a try. We have 5 ovens at present so plenty to play with.
    We have also just had a quantity of mug presses delivered to help over Christmas and I’ve bought a hot plate to pre heat the bottoms of the mugs.
  4. #34
    Junior Member
    Join Date
    May 2021
    Location
    Southampton
    Posts
    11
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I only ever do full top to bottom prints... unless it's mid summer the mug bases are too cold and don't sub..
    Sent from my SM-T970 using Tapatalk
  5. The Following User Says Thank You to rgsearley For This Useful Post:
    gazfocus (16-10-2021)
  6. #35
    Premium Member
    Join Date
    Oct 2015
    Location
    Lancashire, UK
    Posts
    253
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Thanks, will certainly give it a go. Roughly how long do you pre heat for in the oven?
    Thanks again
  7. #36
    Junior Member
    Join Date
    May 2021
    Location
    Southampton
    Posts
    11
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks again
    3 - 4 minutes longer if really cold..
  8. #37
    Senior Member
    Join Date
    May 2012
    Location
    Plymouth
    Posts
    1,895
    Downloads
    0
    Uploads
    0
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    They were in for as long as the others were cooking, so the six mugs came out on a tray and were wrapped, then put in the main oven to cook. Leaving them on the tray while I wrapped them kept the warmth in them. So pop the six in the main oven, put a fresh six on the tray, pop in the other oven to warm.
    Janners
  9. #38
    Premium Member
    Join Date
    Oct 2015
    Location
    Lancashire, UK
    Posts
    253
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Janners
    Thanks for that. So you let them pre heat before wrapping them? I’ll give that a go. Thank you :)
  10. #39
    Senior Member
    Join Date
    May 2012
    Location
    Plymouth
    Posts
    1,895
    Downloads
    0
    Uploads
    0
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Yes, preheat before wrapping.
    Janners
  11. #40
    Senior Member
    Join Date
    May 2012
    Location
    Plymouth
    Posts
    1,895
    Downloads
    0
    Uploads
    0
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    I have just dug out my small oven after a lot of searching I found a wrap. 1 mug 15 minutes. The dial shows 175, the thermometer inside shows 205, I doubt either is accurate. Rhino coated mug prints a treat. Just ordered some new wraps.
    Reason...?
    If there is a problem with my presses in the run up to Christmas, then it's back to the oven!
    This thread prompted me, so thanks folks.
    Janners
Posting Permissions
  • You may not post replies
  • You may not edit your posts
