Join our Premium Membership now and save with Xpres, Ink Express and more! Just £10 per year.....Click the Membership link above.....
User Tag List
Similar Threads
  1. Xpres Chromaluxe Panels
    By arthur.daley in forum General Dye-Sub Chit Chat
    Last Post: 12-11-2015, 10:01 AM
  2. Chromaluxe Panels
    By socialgiraffe in forum General Dye-Sub Chit Chat
    Last Post: 14-02-2014, 08:57 AM
  3. Chromaluxe 20x30cm panels anywhere?
    By Caz in forum Sourcing New Items
    Last Post: 05-01-2012, 12:16 AM
  4. Chromaluxe panels
    By fredster in forum Sourcing New Items
    Last Post: 20-09-2010, 02:31 AM
Results 1 to 5 of 5
  1. #1
    Junior Member
    Join Date
    Aug 2021
    Location
    Oxford
    Posts
    13
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Reusing Chromaluxe panels
    Is there a way to remove sublimated ink from a Chromaluxe panel so I can use it again – it doesn’t need to be as good as new just good enough to do tests with?
    If not does anyone have any good suggestions on what to do with Chromaluxe panels that have an issue or two?
  2. #2
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    No, you can’t reuse it. But you probably could sand it off and than stick aluminium sheet on it?
    <-- How To Print Stuff BLOG
  3. #3
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    4,302
    Downloads
    0
    Uploads
    0
    Mentioned
    6 Post(s)
    Tagged
    3 Thread(s)
    You can print darker, so if you wanted some glossy black metal sheet, you could do that.
  4. #4
    Junior Member
    Join Date
    Nov 2016
    Location
    Malvern
    Posts
    10
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Interesting thought, has anyone ever tried this?
  5. #5
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,433
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    You can't remove the print without removing the polyester coating. Sublimation places the inks in the coating, not on it.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
