User Tag List
Similar Threads
  1. Help! Ink spot appearing after sublimation.
    By joe7906 in forum Printing Problems/Issues
    Last Post: 28-12-2022, 07:24 PM
  2. Mug Sublimation - Ghostwriting / Spots of previous Mug
    By voodoopupp in forum Printing Problems/Issues
    Last Post: 08-10-2020, 03:44 PM
  3. Help Please! Red lines appearing on mug template - Printer Ricoh SG 3110
    By SilentAlf in forum Printing Problems/Issues
    Last Post: 18-12-2014, 08:53 PM
  4. Problem with Ricoh GX3300, lines appearing on print
    By magicfingers in forum Printing Problems/Issues
    Last Post: 07-12-2011, 09:00 PM
  5. yellow bloom appearing, help
    By richgrafix in forum Printing Problems/Issues
    Last Post: 12-02-2011, 12:42 PM
Results 1 to 9 of 9
  1. #1
    Junior Member
    Join Date
    Feb 2022
    Location
    Poland
    Posts
    5
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Problem - Ink spots appearing after sublimation.
    Hello,
    a few days ago, the paper in my printer (Epson L1300) jammed, the printer head smeared the paper, the paper itself was removed and there was no major issue.
    The problem occurred after that, each subsequent printout started pouring spots like in the picture, and to make matters worse, they are not visible on the printout itself (possibly because they are mostly in gray scale) and only come out during sublimation.
    Anyone encountered something like this?
    Already cleaned rollers. Nozzle check test gives perfect results, despite this I ran strong clean, but no changes.
    Maybe I'm wrong and the paper jam had no effect on it, or maybe despite the unobstructed nozzles, the print head itself is dirty and leaves such spots. I do not know if it is possible at all, because the head itself probably has some kind of surface cleaning system.
    Anyone have any ideas what more could be checked?
  2. #2
    Senior Member Mrteajunkie's Avatar
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,154
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    It’s quite common.
    it could be the pizza wheels have ink on them from the jam.
    give them a little clean and send some blank plain paper though a few times to clean off any ink residue.
  3. #3
    Junior Member
    Join Date
    Feb 2022
    Location
    Poland
    Posts
    5
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you, I will try some more cleaning.
  4. #4
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,433
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Quote Originally Posted by SerDnia View Post
    Hello,
    Does this occur with every printout, or only with certain images? Some possible reasons are:
    • Pizza wheel marks (as already posted by @Mrteajunkie ).
    • Dust specks.
    • Ink spatter from the printhead.
    • Stray pixels in the image that are not easily visible on your monitor or the printout.
  5. #5
    Junior Member
    Join Date
    Feb 2022
    Location
    Poland
    Posts
    5
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Already tried 4-5 different images and also 3x the same image. Spots appear on random places, even from the same image.
    Images itself are fine, I've used them multiple times already in the last 2 years.
    Dust - I don't think so, usually don't have problem with that and not on that scale (7-8 mugs in a row).
    I had my suspicions about print head, but is it even possible? Spraying ink with perfect nozzle tests?
    For now, I've done the cleaning, tomorrow will know the results.
  6. #6
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,154
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    in the past I have used a sheet of thick card to clean the rollers rather than paper, but I have seen videos of thick corrugated cardboard being used too.
  7. #7
    Member
    Join Date
    Aug 2021
    Location
    Newcastle upon Tyne
    Posts
    41
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is the ink splatter on your nozzle test sheets as well?
    It sounds to me like there is a lump of debri/fluff stuck somewhere collecting ink and dropping it randomly
    If it was the print head itself would you not expect to see dots of one particular colour rather than a light grey?
  8. #8
    Junior Member
    Join Date
    Feb 2022
    Location
    Poland
    Posts
    5
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by AGS View Post
    The test itself looks clean.
    Today I've made 4 test mugs, 3 of them ended with black/gray dots (but not as many as on previous mugs), 1 was clean. So maybe there is some progress.
    Maybe it's something like this, tomorrow I will try to clean the print head and the area around it. Maybe that will help.
  9. #9
    Junior Member
    Join Date
    Feb 2022
    Location
    Poland
    Posts
    5
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Problem solved. There were a few dust particles on the print head.
    Thank you everyone for the help:).
  10. The Following User Says Thank You to SerDnia For This Useful Post:
    webtrekker (12-05-2023)
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
