User Tag List
Similar Threads
  1. problems with what I see and what I get......
    By elliemillhill in forum Printing Problems/Issues
    Last Post: 25-09-2013, 08:04 PM
  2. Mug problems
    By zzest1964 in forum General Dye-Sub Chit Chat
    Last Post: 28-08-2013, 12:02 AM
  3. Problems please help
    By JOSI74 in forum Printing Problems/Issues
    Last Post: 15-06-2011, 03:04 PM
  4. How to choose/where to begin...
    By justme in forum Heat Presses
    Last Post: 18-03-2011, 08:07 PM
  5. PM Problems
    By Andrew in forum Forum Information/Updates etc.
    Last Post: 01-06-2010, 09:55 AM
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
  1. #11
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    Droping temp is normal. What i do is put the mug in the press. Wait untill temp stop droping then switch counter on. Set it 180. Should get perfect mug.
    <-- How To Print Stuff BLOG
  2. #12
    Member Scotty@BMS's Avatar
    Join Date
    Jan 2010
    Location
    Wimborne Minster, Dorset - Be jealous...
    Posts
    399
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sizer View Post
    (yh templates definately to big top to bottom, currently 95mm x 210mm, may knock it down to 85mm x 200mm to see if that helps)
    Forgot to add the process we used :
    Waited for machine to hit 170 deg.
    Put in mug
    Started Timer
    When it beeped removed Mug and peeled paper.
    Instructions that came with heat press I think say...
    Wait for machine to get to 170
    Put in mug and temp will drop
    Wait for temp to rise to 170 again then press timer button
    After timer has beeped, press timer button again then wait a further minute
    Remove mug.
    Si, if you let your press come up to temp with no mug in the blanket, you're gonna burn the crap out of it in no time! Also, the times I gave you are spot on for the Sublijet inks, when you have the profile sorted you should see improvements. Cook too long and too hot your blacks will turn a dirty brown. The last thing to consider is whether your press is actually heating to the temp it says it is. I'd suggest a infra-red thermometer to check it's actually hot enough in the first place.
  3. #13
    Junior Member
    Join Date
    Oct 2011
    Location
    Hampshire
    Posts
    19
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  4. #14
    Junior Member
    Join Date
    Oct 2011
    Location
    Hampshire
    Posts
    19
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Scotty@BMS View Post
    So are we meant to put the mug in when we turn the machine on?
    What is the full process you use start to finish?
  5. #15
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    Is good to have one "heating mug" that is always in when press is heTing up.
  6. #16
    Member
    Join Date
    Mar 2011
    Location
    Warrington
    Posts
    651
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use to turn my press on with a dummy mug in
    Cant remember what settings it was - i used them from the bms website
    When it got to the correct temp it beeped
    I replaced the dummy mug with the one I wanted to print and press start
    remove the mug when it counted down to 0 (i did used to swap the mug over half way through, some people do, some dont)
    I also dipped in luke warm water to cool down and stop the sub process..
  7. #17
    Junior Member
    Join Date
    Oct 2011
    Location
    Hampshire
    Posts
    19
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by TPM View Post
    Thanks for that will bear all that in mind on the next one!
  8. #18
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    but you need colour profile :) I can tell... picture on te mug is sooo diferent then oryginal one. or is it just the bad photo???
  9. #19
    Junior Member
    Join Date
    Oct 2011
    Location
    Hampshire
    Posts
    19
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Paul View Post
    The photo is very warm, taken in natural light, long exposure and wrong whitebalance setting...lol
    In reality the images is pretty good, could just do with the black being blacker. Although I expected that with a B&W picture. Im waiting for the colour profile before we try a colour photo as i think that may be a whole different story.
    Although I could probably improve the colour settings in Photoshop its on RBG1998 at the moment, when printing it lets the colour management in the printer decide colours.
  10. #20
    Junior Member
    Join Date
    Oct 2011
    Location
    Hampshire
    Posts
    19
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    3rd time lucky!
    Tried a colour image/design this time and it looks sweet as....
    This time, preheated with a mug in the machine to 180d, then swapped mugs and pressed for 160s followed by dunking in luke warm water.
    (the photo of the happy couple is sharper than shown in the photo)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
