User Tag List
Similar Threads
  1. Contour cutting an image
    By Bob @ Prestige in forum Vinyl Cutters
    Last Post: 30-11-2014, 11:33 PM
  2. Contour cutting with cameo
    By Maup in forum Vinyl Cutters
    Last Post: 01-10-2014, 08:43 AM
  3. contour cutting mh refine 721
    By Frostee in forum Vinyl Cutters
    Last Post: 04-06-2014, 01:09 AM
  4. contour cutting
    By plugy in forum Software
    Last Post: 08-07-2012, 12:53 AM
  5. contour cutting on summa d60
    By naeem in forum Graphics & Artwork
    Last Post: 07-12-2010, 01:18 PM
Results 1 to 5 of 5
  1. #1
    Member
    Join Date
    May 2012
    Location
    sandbach
    Posts
    59
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    contour cutting in flexi
    I have flexisign 8.5 and trying to cut images out but cannot figure out how to achieve this.
    if i import an object i click outline but get a rectangle around the image and not a line that follows the outer of the image.
    Also i have tried to vectorise the image when i do it has auto plotted the outline but i cannot adjust this as i would like to bring in a bit to avoid any white marks.
    Next i want to insert plot lines to send to my printer but cannot find how to do this.
    Anyone explain in simple terms please thanks.
  2. #2
    Senior Member mrs maggot's Avatar
    Join Date
    Dec 2009
    Location
    kettering, northants
    Posts
    3,365
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    on you tube there are loads and loads of instructional videos, might be worth checking, what type of image are you importing ?? normally there will be a rectangle around the image that you load, and then weed. might also be worth checking uksign forum, or one of the others where flexi is discussed more frequently (on here the vinyl section is smaller and not as busy, as its mostly for dye sub)
    [h=A dictionary is the only place where success comes before work]5[/h]Laura
  3. #3
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    I think you tring to cut jpg :-) make sure your image is made curves. O tried to contoir cut va flexi 8,5 but could not doit. Flexi 10 can do that.
    <-- How To Print Stuff BLOG
  4. #4
    Member
    Join Date
    May 2012
    Location
    sandbach
    Posts
    59
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There are vids on u tube but for 8.1 not 8.5, if i type text in i get the option to change outline color and it gives me a contour line to adjust, but if i import a pic a vectorised on it already has plotted lines around it but i cannot adjust them or insert plot marks befor i send to print
  5. #5
    Join Date
    Dec 2009
    Location
    Posts
    3,365
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you might need to ungroup the image ?? i work in corel and them inport in the finished item, so not too sure, like i say try the sign forums, as they deal a lot more with cutters
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
