User Tag List
Similar Threads
  1. Contour cutting an image
    By Bob @ Prestige in forum Vinyl Cutters
    Last Post: 30-11-2014, 11:33 PM
  2. Contour cutting with cameo
    By Maup in forum Vinyl Cutters
    Last Post: 01-10-2014, 08:43 AM
  3. contour cutting mh refine 721
    By Frostee in forum Vinyl Cutters
    Last Post: 04-06-2014, 01:09 AM
  4. contour cutting in flexi
    By plugy in forum Software
    Last Post: 30-05-2012, 11:27 AM
  5. contour cutting on summa d60
    By naeem in forum Graphics & Artwork
    Last Post: 07-12-2010, 01:18 PM
Results 1 to 4 of 4
Thread: contour cutting
  1. #1
    Member
    Join Date
    May 2012
    Location
    sandbach
    Posts
    59
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    contour cutting
    i would like to know if there is a way to contour cut around the letters on the logo away from thebackground.
    I have photoshop, corel, and flexi but am a beginner so please explain if anyone has a clue thanks.
    Attached Images Attached Images
  2. #2
    Senior Member WorthDoingRight's Avatar
    Join Date
    May 2012
    Location
    Birmingham
    Posts
    1,081
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi,
    Would you be able to confirm what the cutter is you have and does it have any form of either optical or laser for contour cutting?
    I know that Flex allows contour cutting, however I have no idea whether your cutter has the contour cutting feature.
    Assuming it does then theoretically you could produce a contour to cut around the letters, but again how much of this can be automated and how much requires you to draw the contour to cut I am not aware.
    As I cannot offer any more wisdom than this I will leave it for an expert to come up with the answer and good luck in getting your solution.
    Richard
  3. #3
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    Hi. You dont need laser pointer or optical eye to contoir cut. And not every flexi can cotour cut. I think this feature is.from flexi starter 10. I think in previous ones you.was not able to.do that.
    Any way. If this graphic is a.vector.file then there should not be any problem to cut aroind it :-)
    <-- How To Print Stuff BLOG
  4. #4
    Join Date
    May 2012
    Location
    Birmingham
    Posts
    1,081
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Paul View Post
    Well I was working on the fact that it appeared to be a jpg created with I imagine an online cool text generator lol
    Having struggled just to assemble a stand and mount a cutter on it from the chinglish instructions I have as yet not had the courage to attach it to the pc yet. Although I am looking forward with trepidation to trying signcut, flexi and signblazer out to see what works.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
