User Tag List
Similar Threads
  1. Ink for Epson 1400
    By Ricky in forum Printers
    Last Post: 09-06-2013, 12:02 PM
  2. What's more fun than clearing blocked Epson nozzles?
    By mgibbs in forum Transfers & Transfer Papers
    Last Post: 23-10-2012, 10:07 AM
  3. Epson Stylus Pro 4400 printead blocked
    By Lorcan in forum Printing Problems/Issues
    Last Post: 14-09-2011, 07:15 AM
  4. Epson 1400 (Chromablast) Printer blocked Dark Cyan
    By AdamB in forum Printing Problems/Issues
    Last Post: 25-01-2011, 05:09 PM
  5. Epson 585 & 1400
    By Steve in forum Printers
    Last Post: 26-08-2010, 11:00 AM
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Member
    Join Date
    Nov 2009
    Location
    Durham
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having similar problems on my 1400 too. The test print shows about 40% of the Cyan.
    I have reinserted original Epson cartridges and the test print was fine. The CISS system is new ( the ink tanks that I fill up aren’t new though ). I have sucked the Cyan cartridge and it’s constantly 'bubbly'. So, I added new ink into the CISS Cyan cartridge and the test print was the same.
    So I’m guessing it’s not the printer as the original cartridges printed fine. The CISS system is new. Could it be the ink tanks?
    Any help would be appreciated.
  2. #12
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,432
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    Have you tried sucking a fair bit through to see if the bubbles go? Sounds like an air leak to me.
  3. #13
    Member
    Join Date
    Jan 2011
    Location
    Melksham
    Posts
    430
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did the ciss not come with ink tanks?
  4. #14
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    4,303
    Downloads
    0
    Uploads
    0
    Mentioned
    6 Post(s)
    Tagged
    3 Thread(s)
    Make sure anywhere there is a link/joint/valve on the cyan line that it is tight.
    If the system is new, I'd be asking your supplier for support - if not you could try some glue of some kind to make sure all the joints are sealed ... but be careful that the glue doesn't actually go into the lines and block them!
  5. #15
    Member
    Join Date
    Nov 2009
    Location
    Durham
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have tried sucking the ink through the printer cartridge side but the bubbles kept coming through.
    We didnt get ink tanks as we had problems with our old CISS so didnt need new ink tanks before.
    Many Thanks
  6. #16
    Member
    Join Date
    Nov 2009
    Location
    Durham
    Posts
    30
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    where would the air leak be?
  7. #17
    Premium Member
    Join Date
    Nov 2011
    Location
    Posts
    4,303
    Downloads
    0
    Uploads
    0
    Mentioned
    6 Post(s)
    Tagged
    3 Thread(s)
    the air leak is most likely to be at any of the joints in the system - it is unlikely that there is a hole in the actual tube, but possible one of the joints has come loose.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
