User Tag List
Similar Threads
  1. Epson B1100 Stylus Printer - new A3+ printer
    By Paul in forum General Dye-Sub Chit Chat
    Last Post: 09-07-2010, 01:13 PM
Results 1 to 4 of 4
  1. #1
    Member
    Join Date
    May 2012
    Location
    sandbach
    Posts
    59
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up printer keeps blocking
    i have an epson p50 inkjet, and a ciss sytem.
    The problem is everyday i come to use it the nozzle is blocked i have run nozzel checks and taken out the print head and flushed through several times with cleaner.
    But it still clog's surly this inst normal is it.
    What could be wrong bad ink, the ciss system bad nozzle, the printer is 2months old and running a ciss system and ink from coralgraph.
    Thought about useing the refilable cartridges but unsure if it will make a difference any help would be appreciated thanks.
  2. #2
    Senior Member bms's Avatar
    Join Date
    Oct 2009
    Location
    Dorset
    Posts
    4,079
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Justin has the P50 so perhaps he can help. Specific support is limited to fellow users when a non-standard printer is used. General advice may be forthcoming, but it could be the inks, the ciss or the printer - undoubtedly it is one of these! I'd guess the ciss to be the first thing to look at.
  3. #3
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    4,303
    Downloads
    0
    Uploads
    0
    Mentioned
    6 Post(s)
    Tagged
    3 Thread(s)
    I would be surprised if it is not an air leak in the CISS, and your printer is fine. Swap out for refill carts to see where the problem actually is.
  4. #4
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,432
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    Same advice as above, rule out the CIS by checking with original or refil carts. I've run mine for a long time now with refil carts and done 2 maybe 3 head cleans in it's lifetime.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
