Hi There
I am using Windows 7 64 bit OS, Ricoh SG3110DN printer with Sublijet-R 3110 ink, Trupix A4 sublimation paper and a Coralgraph Flat T shirt Press 23x30cm Swing Digital Version heat press.
All was working ok as I was learning to use the equipment but suddenly my transfers are producing very faded poor quality results. I have printed onto several tee shirts for teddy's and I originally got great results on these but now you can barely make out the image on the finished product and could not possibly use them.
I have checked that the Powerdriver is set up correctly within Photoshop Elements and that I am printing onto the correct side of the paper.
I am running low on black and cyan ink. This is the only explanation that I can come up with. However, the problem occurred before the ink level got as low as it is now. I will be replacing the ink at the end of the week so should I hold off on printing anything else until then? I did do a mug which I did on a Schulze Mug Press and it worked out ok although the background was a little more faded that what I thought it should be but the photos came out perfect. This is making me think that it may be a problem with the heat press.
I am pressing for 40 seconds at 200c onto the Teddy Tee shirts, which as I've already mentioned, worked fine a few weeks ago but no longer produces the good results. Does anyone have any ideas? any or all advice would be appreciated
kind regards
