User Tag List
Similar Threads
  1. Clocks
    By Tania in forum General Dye-Sub Chit Chat
    Last Post: 30-01-2014, 04:07 PM
  2. Blank clocks
    By Mugman71 in forum General Dye-Sub Chit Chat
    Last Post: 03-01-2014, 09:43 AM
  3. Subli Clocks ..
    By Volusian in forum Sourcing New Items
    Last Post: 04-10-2013, 05:56 PM
  4. Desk clocks
    By gstk in forum General Dye-Sub Chit Chat
    Last Post: 17-11-2011, 10:25 AM
  5. clocks
    By smitch6 in forum General Dye-Sub Chit Chat
    Last Post: 12-02-2011, 02:20 PM
Results 1 to 9 of 9
Thread: glass clocks
  1. #1
    Member
    Join Date
    May 2011
    Location
    sussex
    Posts
    44
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    glass clocks
    Hi, im having a problem with some glass clocks, there are white filmy patches
    on the front of the clock which dont show until you heatpress them, when you
    wet it to get rid of it it clears but when it dries its shows up again.
    Ive tried hot water, hot soapy water and turps, and its still there. Can anyone
    help or have had the same problem
  2. #2
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,430
    Downloads
    7
    Uploads
    1
    Mentioned
    43 Post(s)
    Tagged
    7 Thread(s)
    Are these patches cloudy like the transfer hasn't taken properly? I tried a different glass clock the other day and had that problem, wondered if it needed pre-heating. I turned it over and cooked for considerably longer than usually needed and the problem cleared. Paul has a great tutorial video on clocks btw.
  3. #3
    Member
    Join Date
    May 2011
    Location
    sussex
    Posts
    44
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes but its on the right side of the clock, ie not on the side where you put the design.
  4. #4
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    Do you press them up side down? Ie transfer on the bottom?
    <-- How To Print Stuff BLOG
  5. #5
    Member
    Join Date
    May 2011
    Location
    sussex
    Posts
    44
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, so it draws up rather than pressing down
  6. #6
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    there you go then :)
    heat is burning glass coating so you getting patches. try to press it transfer on top of the clock and use silicon matt. this should help.
  7. #7
    Member
    Join Date
    May 2011
    Location
    sussex
    Posts
    44
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    so is there a coating on the front of the glass? thought it was just plain glass.
    When I first started doing this, I did do glass with transfer on the top and press down and it never worked, only ever worked drawing up.
    So are you saying put silicon mat on the bottom, then the glass clock transfer side upwards, bit of protective paper then press?
    Or another silicon mat on the top between transfer and heat plate?
  8. #8
    Member
    Join Date
    May 2011
    Location
    sussex
    Posts
    44
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    can you send me the link to the tutorial please as well:)
  9. #9
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,592
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    glas has a coating but not sublimation one :)
    it is used to make glas shine more. when is polished.
    video here:
    http://www.dyesubforum.co.uk/vbforum...printing-video
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
