User Tag List
Similar Threads
  1. are any of the cheaper (as in 'ebay') cutters worth it?
    By gavtheoldskater in forum Vinyl Cutters
    Last Post: 04-12-2013, 03:46 PM
  2. anyone know about desktop/cheaper laser engravors?
    By gavtheoldskater in forum Misc. Printing
    Last Post: 05-06-2013, 09:27 AM
  3. cheaper square coasters cork backed
    By Kyebie in forum Sourcing New Items
    Last Post: 09-04-2013, 10:15 AM
  4. It Just Gets Cheaper!
    By John G in forum General Dye-Sub Chit Chat
    Last Post: 01-02-2012, 07:58 PM
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
  1. #1
    Member
    Join Date
    Mar 2014
    Location
    Hull
    Posts
    48
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    A cheaper press it has to be
    Ok A cheaper press it has to be, if i need to replace it in a year then so be it.
    Can anyone recommend anything suitable for T-shirts n Hoodies for under £300 - £350ish
    Great forum and I have learned a great deal over the last few days but I still can put my finger on a heat press that sits between the "chocolate teapot" bracket and "lifelong workhorse"
    Member NikGrey's Avatar
    Join Date
    Sep 2013
    Location
    Norwich
    Posts
    910
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The trouble is, not that you might have to replace it sooner rather than later but the heat may not be even across the heat plate !
    I had terrible trouble with my cheap press and never got to use it, I tried to press a transfer and as the press was so un-even it distorted the transfer film and ruined the transfer completely. If you MUST go the cheap route go and test the press first.
    I think I had a bad one, but the way cheaper presses work is the problem as they have an element like an oven which does not cover the whole heat plate unlike the more expensive ones which use micro coils that cover edge to edge.
    I say go for it though as if I hadn't bought my cheap setup I wouldn't have done anything at all.
    In any case its good to go through the cheap route just for the experience.
    Good Luck, you will love it once you start producing things.
    My website is open:
  3. #3
    Member
    Join Date
    Mar 2014
    Location
    Hull
    Posts
    48
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Nik,
    Yea I have read a few of your posts on this very subject and taken it on board.
    I guess I could push to 400ish for a decent used press but there are no decent used ones on ebay bay right now.
    My silhouette cameo cutter will be here tomorrow. Ill have to discipline myself and not be tempted to buy one for the sake of it.
    Think I will go for a work around on a printer so I can buy a better press. Perhaps try one of these http://www.cityinkexpress.co.uk/chea...er-printers/a3
  4. #4
    Member Scotty@BMS's Avatar
    Join Date
    Jan 2010
    Location
    Wimborne Minster, Dorset - Be jealous...
    Posts
    399
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Markola. If you have £350 in the pot I think you could pick up something very decent that'll do the job you want it to do, look around the various suppliers I'm sure you'll see something that'll take your fancy at a good price.
  5. #5
    Member
    Join Date
    Mar 2014
    Location
    Hull
    Posts
    48
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Scotty@BMS View Post
    I'm tempted by the two clam presses on BMS but not sure how well the larger of the two distribute the heat. Been sniffing around for some reviews of these two. the 38x38 should be big enough. but if the bigger one performs then why not.
  6. #6
    Join Date
    Jan 2010
    Location
    Posts
    399
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would actually prefer the smaller (and cheaper) one for doing tees, personally.
  7. #7
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    4,303
    Downloads
    0
    Uploads
    0
    Mentioned
    6 Post(s)
    Tagged
    3 Thread(s)
    There's always decent used presses on Ebay! But the good ones go quick, and you need to know what to look for.
    We bagged a PressMech off there for £50 buy-it-now the other day! ;-)
  8. #8
    Member
    Join Date
    Mar 2014
    Location
    Hull
    Posts
    48
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would agree, I have seen loads of great presses on ebay. That was until I was ready to buy. If you find you have one too many give me a shout ;-)
  9. #9
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,397
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    There was a PressMech that ended a month ago for £109, light use too, why waste money on dodgy Chinese stuff?
  10. #10
    Member
    Join Date
    Sep 2013
    Location
    bexhill
    Posts
    95
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I never seem to find cheap decent presses on Ebay !!!
    Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
    and now a Roland SP-300v Versacamm !!!!!!
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
