User Tag List
Similar Threads
  1. Epson 1500w problems
    By pesketta in forum Printers
    Last Post: 05-04-2015, 12:39 PM
  2. epson 1500w ink
    By baracus in forum Printers
    Last Post: 03-11-2014, 10:30 PM
  3. Epson 1500w
    By jlbn512 in forum Printers
    Last Post: 26-04-2014, 01:29 PM
  4. epson 1500w
    By bigj2552 in forum Printers
    Last Post: 23-04-2014, 11:33 PM
  5. Best CISS ssytem for Epson 1500w
    By kevdsn in forum Printers
    Last Post: 13-03-2014, 10:42 AM
Results 1 to 6 of 6
  1. #1
    Premium Member Angloman's Avatar
    Join Date
    Oct 2013
    Location
    yorkshire
    Posts
    257
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    HP 7500A or Epson 1500w
    Has anybody used these printers for sublimation,both have ciss and ink available
    Both are A3,hp is all in one where the epson 1500w is cd printer as well with better spec but printer only
    thanks in advance
  2. #2
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    4,303
    Downloads
    0
    Uploads
    0
    Mentioned
    6 Post(s)
    Tagged
    3 Thread(s)
    You can't use HP printers for sublimation. If you want an alternative to Epson, then look at Brother inkjet printers.
  3. #3
    Join Date
    Oct 2013
    Location
    yorkshire
    Posts
    257
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    why not hp ? they have a ciss available
    Directdesignsupplied.co.uk
  4. #4
    Join Date
    Oct 2013
    Location
    yorkshire
    Posts
    257
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    can this be used
    Brother MFC-J5910DW All-in-One Inkjet Printer
  5. #5
    Join Date
    Oct 2013
    Location
    yorkshire
    Posts
    257
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    looks like i might need paul again for a profile,just bought
    Epson WF7015 Printer
  6. #6
    Premium Member
    Join Date
    Nov 2011
    Location
    Posts
    4,303
    Downloads
    0
    Uploads
    0
    Mentioned
    6 Post(s)
    Tagged
    3 Thread(s)
    Yes, you can use the Brother.
    It's not the availability of CISS or refill carts that defines whether you can use sublimation ink in a printer, it's the print head technology. If a printer uses heat in the print head (to effectively boil the ink, and the increae of pressure forces the ink out - a la bubble jet) then the ink will sublimate in the printer. Epson's printers uses an electronic system, called piezo-electric which doesn't have this problem. Brother's also use this type of technology, along with a load of wide format printers use Epson's print heads.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
