I'm having issues with contour cutting.
Firstly i tried with signcut.
when setting up it draws the + and allows me to move the plotter left and right to calibrate the offset. when i want to actually do the contour cut though and have to move the lazer to the registration marks the plotter will not move at all.
now i've had issues with signcut in the past so figured i'd give something else a try in the mean time. Downloaded a trial of winpcsign.
i can cut designs fine but once again when trying the contour cut the plotter wont budge. Not even the offset testing.
what type of thing could be causing this? i've got my plotter connected by usb and i'm using windows 7. the usb driver installed is the ch340 one and im on com port 6.
any help would greatly be appreciated
