xpres i believe also will help guide you at their hq - you can lessen the wastage costs by cutting certain things up like mousemats etc, but for mugs, expect to loose a few before you get them right - take some of your printed sheets with you can see if it is your print that is at fault and also your mugs, it would help on here if you posted up images of some that you have pressed already so others can comment on them
