Sublicotton
A11kns
Re: Sublicotton
Post by A11kns »
So got the 3110 set up and got some sublicotton paper and I have to say I'm very impressed.
However... Went to print a second design today and the result wasn't what I was expecting.
First press... Not bad
Second... Looks raised... Too much powder???
And how can I stop these little bits?
Re: Sublicotton
Hi. Silly question as we have only been told about this sublicotton from Scott at BMS but do you reuse the same powder each time? Could it be that the print was still wet, powder got coated but was then tipped back into the tray and ruined the next one? Only a guess.
A11kns
Re: Sublicotton
Post by A11kns »
UK Printed Mugs;111434 wrote:Hi. Silly question as we have only been told about this sublicotton from Scott at BMS but do you reuse the same powder each time? Could it be that the print was still wet, powder got coated but was then tipped back into the tray and ruined the next one? Only a guess.
That's a really good point! I didn't think about that!!! I think from what I've read you use the left over again, maybe not!
Ian66
Re: Sublicotton
Post by Ian66 »
I did some tests with sublicotton with varying results. Some people print through Powerdriver but when I did I found that this seemed to throw too much ink onto the paper and my result was similar to yours with black dots especially around solid text. I tried using the sublicotton profile but couldn't get decent image quality. I will have another play in due course. I was using a Ricoh 7100 as I want to print A3 designs, if I ever get sorted. Has anyone had success with this system and if so what printer settings do you use?
A11kns
Re: Sublicotton
Post by A11kns »
First was ok for me using the ICC but not the second
A11kns
Re: Sublicotton
Post by A11kns »
Just double checked the instructions and it says save the excess to be reused. I'm not sure why it was so poor.
Re: Sublicotton
I think Scott is back at BMS next week for accurate advice. My only "guess" is that perhaps the procedure of applying the powder needs to be less rigorous so any powder that sticks to the print doesn't get thrown off. There must be someone on this forum though that also uses it.
A11kns
Re: Sublicotton
Post by A11kns »
UK Printed Mugs;111498 wrote:I think Scott is back at BMS next week for accurate advice. My only "guess" is that perhaps the procedure of applying the powder needs to be less rigorous so any powder that sticks to the print doesn't get thrown off. There must be someone on this forum though that also uses it.
Might be right.
I need to get this down as I'm about to taken an order of about 20 shirts lol
Re: Sublicotton
Yes you reuse the powder. The powder only sticks to the wet ink so the rest of the powder is reused.
A11kns
Re: Sublicotton
Post by A11kns »
Do you think I used too much?
