Liyu Vinyl Cutter Problem
mikeoooze
Re: Liyu Vinyl Cutter Problem
Post by mikeoooze »
Hi, I've had a Liyu vinyl cutter for 4 years, bought from Signzworld. Never had a single problem until today. Now, I have areas where it looks as though the pressure of the blade, or depth of cut has reduced, meaning that when it comes to weeding, the vinyl just tears in certain areas. In some places on the vinyl, the blade does not even cut at all. Anyone had a similar problem? I have replaced both the blade and blade holder without any success.
Check different usb cable.
Not sure about the Liyu, but have you tried flipping the cutting strip (the horizontal strip below the blade)? After 4 years of use it may have become uneven.
mikeoooze
Post by mikeoooze »
Sorted - good old WD40... Thanks for the replies.
Great, but remember WD40 is essentially penetrating oil and not a lubricant, so maybe a drop of light oil will prevent that happening again.
mikeoooze
Post by mikeoooze »
webtrekker;122131 wrote:Great, but remember WD40 is essentially penetrating oil and not a lubricant, so maybe a drop of light oil will prevent that happening again.
Thanks. Will do. It was Mark at Signzworld who suggested it, very helpful. :smile:
Manuel V
Post by Manuel V »
I think you have a damaged the long ribbon cable. put the carrier in start and then put enter.
then you advance the carrier with the arrow little by little. the blade must be up and if at any time it goes down to the cutter floor, it is because there is no voltage and the cable is damaged. It costs about 35 dlls in China.
Mrteajunkie
Has thanked: 6 times
Been thanked: 4 times
Post by Mrteajunkie »
Manuel V;148230 wrote:I think you have a damaged the long ribbon cable. put the carrier in start and then put enter.
This post was 4 years old and already solved.
Users browsing this forum: No registered users and 13 guests
