Brother printers for sublimation use.
Re: Brother printers for sublimation use.
mine works great with Tru-Pix
....but i haven't tryed the stuff paul has yet so.......
- WorthDoingRight
mine works great with the papers I have tried - both cheap items from eBay sellers but I haven't tried the expensive stuff like the others (I am happy so far with the results but one paper is definately higher release than the other)
Ok. I should say. My works with coralgraph paper. Some el cheapo ebay paper. Trupix and texprint. Texprint gives best results so far
is that on everything paul?Paul;50323 wrote:Ok. I should say. My works with coralgraph paper. Some el cheapo ebay paper. Trupix and texprint. Texprint gives best results so far
think we all had this discusion on this a while back ????
yep. evrytime i use texprint, its a winer for me. have truepixloaded right now and can not fault it. but texprint relase more ink every time
Paul, just playing devils advocate for a moment....does releasing more ink make a difference to the print?
In my cas, yes. Less pressing time and more vivid colors.
It makes no difference to any other brand of printer. Whatever paper you prefer for other dye-sub printers will apply the same for Brother printers. I prefer TexPrint and TruPix, but I've also used Xpres and Coralgraph.meldean;50305 wrote:Hello Everybody
Im in the process of setting up with a brother printer for sublimation and was wondering if there is a preference on which papers to use to get best results.
Thank You
Talking about TexPrint - When's it coming back in @BMS?....i been itchin to try it after pauls comments, but the stuff has been out of stock for ages now.:rolleyes:
