Plastic ID cards
Re: Plastic ID cards
Looking for some plastic sublimation ID cards that fit in the clear plastic card holders, can anybody help?
We've supplied cut metal for these in the past. Would something like this do? You can print on the white surface and slide them into the plastic holder.
Ordinary plastic will just melt when put in a heat press. You might need to re-think...sublimation sticker is thin and would work okay if you didn't remove the backing to make it sticky, FRP is probably too thickJason;71337 wrote:Thanks, I suggested this but apparently it's definitely plastic they want.
Are ID card printers not sublimation based? ... I worked for a large multinational in my previous career, who had a large staff turnover, and printed off photo/barcode ID cards on the fly for us all, they certainly came out warm/hot to touch when printed.
If the card plastic is polymer based, and a polymer which is heat resistant enough upto 200C, then it should print fine.
Maybe call these guys for a sample and give it a go?
http://www.identificationsolutions.co.u ... 855188ee4e
Day Out Photography
www.dayoutphotography.co.uk | facebook.com/DayOutPhotography | twitter.com/DayOutPhotos
m. 07817 118 717
m. 07817 118 717
