Page 2 of 2
Re: Black Dye On Mugs
Posted: 16 Nov 2014, 20:38
by Boardy2003
i use an epson printer on a CISS the ink i use is called professional ink for ric. ICC profile i dont use i use photo shop then print (sorry im new to this)
by A11kns
pisquee;94099 wrote:You haven't mentioned what ink, printer, or sublimation paper you are using, and whether you have an appropriate ICC profile installed.
All these things can/will affect your colour accuracy.
Sorry to hijack but where is the best place to get icc profiles?
Posted: 16 Nov 2014, 20:48
by pisquee
First place to look for an ICC profile is the manufacturer of your ink - it is specific to your print, and one manufacturer's ICC won't be right for another ink.
If your manufacturer or supplier can't supply one, then you need to get one made, and the best place for these is Paul from this forum, and you can buy them from him here:
http://www.frames4photoshop.info/custom ... ation.html
Posted: 16 Nov 2014, 20:51
by Boardy2003
could it also be the mugs youuse ? all the other colours are perfect no run etc just black goes brown or light green
Posted: 16 Nov 2014, 21:03
by Boardy2003
also my mugs are from monster doodle i seen some bad things online about them so i guess im using rubbish mugs also ? where is the best place to buy 11oz mugs in packs of 78 ?
Posted: 16 Nov 2014, 21:14
by pisquee
Black going brown is often a sign of over cooking/burning the ink
Green is possibly not cooked enough, or your colour management is not right (no ICC)
Check out the supplier section of the forum, if you want recommended suppliers, but you are right in your assumption that bad mugs don't print well.
Posted: 16 Nov 2014, 21:23
by Boardy2003
thankyou for all your help guys :)
