Hi Justin, I had this issue after the last CM3 update. I reverted back to the previous one & it's been fine since.
Keith
Graphtec Corel Plug In - Anyone using?
Re: Graphtec Corel Plug In - Anyone using?
I've had this same problem with CM3 and discovered that making sure CM3 (or any parts of it) are NOT running when you send the job.
Although you can view the design in wire-frame in Coreldraw, are you certain the the properties of the outline object are set to hairline? I'm sure we've experienced similar issues.
Email the design to me and I'll check it cuts on our CE5000.
John
John
CD8 isn't supported it appears but 4 should be, will revisit this again soon.
We're using CD6 without any issues.
