Page 2 of 2
Re: Problem printing metal sublimation plaques / signs
Posted: 23 Nov 2016, 07:52
by Developit
I have had the same issue when printing discs and found that some brands work better than others.
I can't get the smaller silver mirror finish discs to work at all and ended up punching them out of a sheet of dye sub Ali and they worked well. I'm going to try less heat and pressure next time and see if that helps.
Posted: 23 Nov 2016, 17:08
by viccar
on the bottom left hand corner of the photo, it looks like the plastic is still on the metal?
I press bottom plate, paper,metal, image, top platen 180 for 55 seconds
Posted: 23 Nov 2016, 17:11
by viccar
I press bottom plate, paper, metal, image, paper, top platen 180 for 55 seconds
Posted: 25 Nov 2016, 14:36
by Alex810158
Quinsfan;116972 wrote:I believe this is moisture in the material. I have read on here that some people press through the metal with a sheet of kitchen roll to take out the moisture
I agree with Quinsfan. I had the same problem which was resolved by simply placing a sheet of kitchen roll between the subli paper and press/Teflon.
Sent from my SM-G935F using Tapatalk
