D120 nightmare
Ian M
Re: D120 nightmare
Post by Ian M »
Georgestreets;19458 wrote:The other night I managed to get a 1/4 of the page printed then it just stops and the red light comes on.
George, This is the same problem I was having with the cartridges & I contacted the company I bought the printer from. Luckily they were not too far away from where I live & they asked if I could take the printer to them to have a look to see what was going wrong. They tried various different things but in the end they decided to change the chips & hey presto it was working. It was ok for a short time & then the same happened again & again. Talking to other printer & cartridge suppliers it was evident that this was quite a common problem on the D120. As I said before I finished up having several sets of chips in stock & replaced them on a very regular basis. In the end the same explaination started to come from suppliers that it seemed the extra black cartridge seemed to be causing the problem. Now I know this bit will seem a bit silly but, it's what I was told time & time again. It seemed the chips in the two black cartridges seem to have a conflict all of a sudden & would in a way argue between them who was the dominant black cartridge to the point neither of them would play with the other. Like I said sounds really silly but, it did seem to be the case. I think the proof in point here is that the D120 was soon replaced when all these similar problems arose & the replacemt didn't have that extra black cartridge.
I know they'll probably be a few posts dimissing what I have said but it did happen to me & I've just repeated what was said to me by suppliers who were having a nightmare with this printer.
Georgestreets
Re: D120 nightmare
Post by Georgestreets »
hi Ian, it is a nightmare. Thing is I now live in Cyprus and it seems that I'm the only sublimator :-) here. any chance you could point me to a chip supplier?
Thanks again matey
Re: D120 nightmare
did you try remove carts and place them back ???
Georgestreets
Re: D120 nightmare
Hi Paul, yep, so many times that I'm now a cart removal pro :-) the red light just stays on. The transfer press have ignored 2 of my emails and sawgrass are telling me to contact the transfer press. bit of a love triangle going on here or should I say hate triangle.
It's all well and good taking some ones money, that's the easy part.
Ian M
Re: D120 nightmare
Post by Ian M »
Georgestreets;19469 wrote:hi Ian, it is a nightmare. Thing is I now live in Cyprus and it seems that I'm the only sublimator :-) here. any chance you could point me to a chip supplier?
Thanks again matey
George, I used to get mine from a couple of local computer fairs but anyone who sells refill cartridges should have them to sell. I think City Ink Express could help you out & here's their link. http://www.cityinkexpress.co.uk/
Georgestreets
Re: D120 nightmare
Thanks Paul, top dude, I'll give'm a try.
thanks again matey
Re: D120 nightmare
Georgestreets;19473 wrote:Hi Paul, yep, so many times that I'm now a cart removal pro :-) the red light just stays on. The transfer press have ignored 2 of my emails and sawgrass are telling me to contact the transfer press. bit of a love triangle going on here or should I say hate triangle.
Graham's usually pretty good at the transfer press. If all else fails then I think we have the D120 cart & tube assemblies in stock. These are replacement cartridges with tubes fitted for fitting into your existing system. They come filled with Artainium ink. Transfer press should be able to supply these as well.
Ian M
Re: D120 nightmare
Post by Ian M »
Martin, It does seem a bit pointless to spend all that money on a new system when what I suggested should cure the problem as in this similar link http://www.dyesubforum.co.uk/vbforum/sh ... woes-again
Re: D120 nightmare
How old is this system?
Re: D120 nightmare
Ian M;19487 wrote:Martin, It does seem a bit pointless to spend all that money on a new system when what I suggested should cure the problem as in this similar link http://www.dyesubforum.co.uk/vbforum/sh ... woes-again
Who said it was going to cost any money? Graham should be able to provide this free of charge as the original supplier if the system.
Users browsing this forum: Google [Bot] and 8 guests
