flock and flex multilayering
Re: flock and flex multilayering
Well.... This is interesting but it is cold peel. But when you taking backing sheet off it coming off very easy!
John G
Post by John G »
What difference does it make if its hot or cold peel?
AdamB
Post by AdamB »
John G;29297 wrote:What difference does it make if its hot or cold peel?
Ditto, I just re-read this topic again ................................. what difference?
Cold peel need to be cooled before you take backing of as glue need more time to stick to the garment. When multilayering you press only for 3 sec and take the backing of and apply another layer. With cold peel it shouldnt be so easy as this flex wouldnt stick to garment in just few sec and would come of with backing. Is that make sense?
P4UL
Post by P4UL »
I find that with cold peel can stretch the fabric as you peel the backing away, in my experience, causing layers to be out of sync. Hot peel, obviously, you peel away straight away, thus I find it doesn't effect my finished product. Also it is a quicker process with hot peel. Hot peel vinyl tends to be a bit more expensive to purchase.
Anybody else have any preferences or experience with hot/cold peel vinyl flex?
Cold peel from youlo for easy weeding and hot peell from mdp for great price and sticky backing (sometimes to strong tho)
P4UL
Post by P4UL »
Paul;29300 wrote: When multilayering you press only for 3 sec and take the backing of and apply another layer.
You only press the vinyl for 3 seconds?
John G
Post by John G »
I've never done this for such a short time - I always press for time stated in the instructions even with different layers or types of garment vinyl. I can see why, so the 1st colour/layer doesn't get too much heat/time but its never effected the end result (i've only done hi viz like this).
AdamB
Post by AdamB »
When multi-layering I normally press for about 6-8 seconds - anything more would cause shrinkage to the vinyl which would have an affect on the designs I use (6-8 secs works for me but it depends on how much 'fudge factor' you have).
P4UL
Post by P4UL »
I understand why shortening the press time for layering, although I don't, but is 3 seconds enough to release the vinyl onto the fabric?
I just looked at the Yolo instructions for their vinyl...yep, short press time of 10 seconds....wouldn't mind having a sample to look at...
