Page 2 of 3
Re: Coaster - HD Board from TMT
Posted: 17 Sep 2011, 09:29
by AdamB
Jimbo;30713 wrote:For £10 you can buy 6 - 24" x 12" sheets of aluminium in different finishes which could produce 108 coasters and they would last a lot longer than the card ones. You would of course need a 12" shear and a corner rounder.
Jimbo
That's the thing Jimbo - yes this would be cheaper but you'll still need to cut the sheets which take time, where as the coasters are ready to go (good idea though).
Posted: 17 Sep 2011, 09:33
by Paul
Subli metals and bms can cut metal for you. They did for me and done exelent job. All with rounded corners. Problem is it looks pants without backing. So would be nice to stick come cork or rubber as a base.
AdamB;30712 wrote:This is probably the ideal product to advertise for birthdays, weddings etc - used once with pictures/messages ................... might get some myself :-)
hmmm i may get some ti and adcertise my photography oike that :-) just need to have a chat wit local pub. Never to many coasters there....
Posted: 17 Sep 2011, 09:39
by AdamB
metal coasters look good with the little rubber pads on them (packs available in pound shops). It raises them up a little and they look more appealing ;-)
Posted: 17 Sep 2011, 10:37
by totallypersonal
These could be good to try and sell to local pubs and cafe's etc.
Might have to try a few :)
Posted: 17 Sep 2011, 12:56
by Jimbo
AdamB;30714 wrote:That's the thing Jimbo - yes this would be cheaper but you'll still need to cut the sheets which take time, where as the coasters are ready to go (good idea though).
I agree, although the aluminium works out cheaper, when you allow for extra time for cutting them up there's probabaly no difference in cost, however think of the difference in what you could sell the aluminium coasters compared to the cardboard ones.
Jimbo
Posted: 17 Sep 2011, 13:01
by AdamB
Jimbo;30722 wrote:I agree, although the aluminium works out cheaper, when you allow for extra time for cutting them up there's probabaly no difference in cost, however think of the difference in what you could sell the aluminium coasters compared to the cardboard ones.
Jimbo
Good point ;-)
Posted: 20 Sep 2011, 16:56
by Paul
I just received my samples from TMT! verry fast ti was i must say. they send 6 coasters to try out. They do in did look like verry posh cardboard coasters with verry shiny surface. I am just about to print couple to see how they print. I dont know any time or temp so will have a go with standard test temp for me: 185C for 50ces. will upload picture soon.
Posted: 20 Sep 2011, 17:05
by AdamB
Yes - please do post pictures paul. It would be good to see a review for these .................... I'm thinking Xmas Dinners and all that :-)
Posted: 23 Sep 2011, 00:02
by sarahjayne
Jimbo
If you use aluminium do you need to put a sublimation coating on top of them? And is it a regular metal corner rounder punch you use - as I have a couple of those - one for heavy duty chipboard and one for cardstock ....
Posted: 23 Sep 2011, 08:50
by Jimbo
sarahjayne;31018 wrote:If you use aluminium do you need to put a sublimation coating on top of them? And is it a regular metal corner rounder punch you use - as I have a couple of those - one for heavy duty chipboard and one for cardstock ....
The aluminium is coated for sublimation. I buy it in 24" x 12" sheets for about £1.70 per sheet in up to 9 different finishes, 0.5mm thick or in case of white and grained sliver also in 0.75mm.
You'll need a metal shear and a corner rounder if you want to cut it yourself.
Jimbo
