Broken/grunge font suitable for vinyl - is there one?
mrs maggot
Re: Broken/grunge font suitable for vinyl - is there one?
Post by mrs maggot »
you can use a piece of the backing vinyl, if its sticky enough to help take lots off and then just do i final weed, i roll mine which helps loosen the edges and then - just like you would fluff from a jumper - dab the vinyl backing over the back of the unpeeled vinyl and it does the job quite quickly
hidehi
Post by hidehi »
stuart;48955 wrote:try feast of flesh its ok and easy to weed
stu
Thanks Stu, will have a look :o)
hidehi
Post by hidehi »
Great tip Laura, thanks!
RogerC
Post by RogerC »
Try leaving the cut vinyl overnight as well...it makes weeding so much easier on the fiddly bits.
hidehi
Post by hidehi »
I didn't know that Roger, thanks!
