Page 2 of 3
Re: Mug Problems
Posted: 18 Sep 2012, 17:48
by Paul
you should check your nozzle test :)
Re: Mug Problems
Posted: 18 Sep 2012, 18:04
by quasar
Nozzle check print out looked fine, but I may do a print head clean anyway to see if it improves the situation.
Re: Mug Problems
Posted: 18 Sep 2012, 18:09
by RogerC
I'm by no stretch of the imagination an 'expert' so take this with a degree of doubt but that looks like a heat mat problem to me......maybe you're clamping the mug too tight?
Re: Mug Problems
Posted: 18 Sep 2012, 18:12
by quasar
Thank you for that, I will check the tension and try again
Re: Mug Problems
Posted: 18 Sep 2012, 21:07
by WorthDoingRight
I wonder if you should not try a standard plain paper setting also if none of the above suggestions help. Those white lines can be a product in the past of the following: damp paper or wet ink (let transfer dry a while especially if using a high quality setting), uneven pressure around the mug, not long enough in the press (try 180 for 180), maybe printer banding.
Anyway I hope you fix it soon.
Re: Mug Problems
Posted: 19 Sep 2012, 08:22
by quasar
Thank you . Gradually checking things off the list and trying different things
Re: Mug Problems
Posted: 19 Sep 2012, 12:33
by quasar
Nozzle checked, print head cleaned, pressed lowered slightly, time increased and it is all working really well.
thank you all for your help
Re: Mug Problems
Posted: 19 Sep 2012, 12:35
by WorthDoingRight
Well thats good news - glad we could all chip in to help.
Re: Mug Problems
Posted: 19 Sep 2012, 13:11
by RogerC
Good result.......don't you just love this place when the combined advice works.....:biggrin:
Re: Mug Problems
Posted: 19 Sep 2012, 14:06
by Charlie_
RogerC;53830 wrote:Good result.......don't you just love this place when the combined advice works.....:biggrin:
YUp I do .......................................
