Page 2 of 2
Re: Ricoh SG 3110DN How do you set it to Mirror the image?
Posted: 27 Jan 2013, 17:17
by viccar
I also use the ricoh sg3110 and powerdriver and it does mirror if you tick the box
Posted: 27 Jan 2013, 19:44
by JHP
The power driver looks a lot different to what i use in the screen shot. Am i missing something because there is no mirror box to tick anywhere on mine?
Posted: 27 Jan 2013, 20:28
by bms
JHP;64073 wrote:The power driver looks a lot different to what i use in the screen shot. Am i missing something because there is no mirror box to tick anywhere on mine?
When you go to print, do you select the Ricoh SG3110 or the PowerDriver? If you don't see PowerDriver in the list of "printers" then you don't have it installed. Assuming you are using a PC (not Windows 8) then download and install PowerDriver from here:
http://www.sawgrasseurope.com/technical ... c-profiles
Posted: 27 Jan 2013, 22:22
by JHP
Thanks martin, cannot understand why on earth Sawgrass didnt mention this when i phoned them!
Powerdriver installed.
Posted: 28 Jan 2013, 19:32
by bms
JHP;64079 wrote:Thanks martin, cannot understand why on earth Sawgrass didnt mention this when i phoned them!
Maybe it was lateral thinking - an answer to a question without elaboration!
Posted: 30 Jan 2013, 14:51
by doe
can i be having the same problem with a mac and using photoshop cs6
just moved from my epson to the ricoh sg3110dn and i can't get it to reverse image
hope someone can help
