Getting started with sublimation - Apple Mac Compatibility
rabb
Re: Getting started with sublimation - Apple Mac Compatibility
Post by rabb »
You misunderstand me Paul. I don't have an issue with ICC profiles on my iMac. I use photoshop with a custom ICC profile. Colour management on the printer driver is turned off.
What I am saying is that I believe Catalina has introduced an ICC problem. I use Mojave which is absolutely fine :)
Paul;146080 wrote:So how do you use your Icc on Mac? What software do you use to print from?
Got to Library > Colorsync > Profiles and see if you have any there. If you do, your mac is using them. Don't forget any printer you use. Comes with drivers and that's what is using icc profiles.
So please check in your printing software if you can set them.
5H17
Post by 5H17 »
Paul;145964 wrote:If you have a mac, photoshop and icc, dont worry. crack on. it will work lovely.
PM me and i will send you colour settings for photoshop
Apologies for digging up an old thread, but I have a similar issue. Which Mac OS are you using Paul? I understand the issue began with Catalina, which is what we run. We are heavily invested in Macs so I've shied away from Epson printers for that reason, but both of our Sawgrass printers now have issues and need replacement.
I've no desire to switch to windows whatsoever and I'm pretty much resigned to buying an SG1000, but if there are other options I am all ears.
Has thanked: 13 times
Been thanked: 12 times
I have 2 x VJ628 printers for sale, PM if you're interested.
colebag
Post by colebag »
I run a Mac on Catalina no problems with printing sublimation I would say it was easy then my windows for setting up a icc profile and I run 2 epson printers no problem at all any setting info you need just let me no and can help you out
5H17
Post by 5H17 »
colebag;147105 wrote:I run a Mac on Catalina no problems with printing sublimation I would say it was easy then my windows for setting up a icc profile and I run 2 epson printers no problem at all any setting info you need just let me no and can help you out
Which printers and inks do you use if you don't mind me asking?
colebag
Post by colebag »
5H17;147113 wrote:Which printers and inks do you use if you don't mind me asking?
I'm using sublinova inks from ink experts with there papers and profiles on my Mac and a epson l3111 printer for sublimation. also using a epson workforce for printing my labels with default settings for that one.
