AAAAAAAAAAAAGGGGGGGGHHHHHHHH - my brain hurts!!
colglyn
Re: AAAAAAAAAAAAGGGGGGGGHHHHHHHH - my brain hurts!!
Post by colglyn »
Hi just a quick question i got epson 1400 and i use the CISS system, if i put refillable cartridges in now, do i have to get a CISS profile done or should it be ok to print, and can i fill these with Visi-sub inks thanks
smitch6
Post by smitch6 »
it won't effect the print set up in any way or shouldn't anyway :)
have no idea about ink sorry
Changing from a CISS to refillable carts won't change your ICC profile needs.
JSR
Post by JSR »
In its simplest terms, a colour correction profile tells your specific printer how much of each colour from your specific inkset to lay down to achieve the right colours on your chosen substrate.
How the ink gets to the printer is of no consequence. So long as the ink doesn't change, and the printer doesn't change, and the substrate is the same, then the same profile will be fine.
