Page 3 of 5
Re: Advice on faint transfers please
Posted: 08 Nov 2012, 19:40
by Paul
what software you used to print this one?
Posted: 08 Nov 2012, 19:43
by mummywebb
Paul;58325 wrote:what software you used to print this one?
I just used the Sil Studio software.
Posted: 08 Nov 2012, 19:47
by gorgall2
Use the whiter side of the paper.
Posted: 08 Nov 2012, 19:49
by mummywebb
gorgall2;58329 wrote:Use the whiter side of the paper.
I think I did tbh it was dark by the time I did it so might be better to check again daylight
Posted: 08 Nov 2012, 19:58
by bms
mummywebb;58330 wrote:I think I did tbh it was dark by the time I did it so might be better to check again daylight
In the box of paper, the printing side is face up. If your image transferred fine onto HTV (don't know what this stands for!) then in theory it should transfer onto other products. The fabric or compressed coasters will give a matte effect when printed - try one at 200 degrees for 90 seconds and see if that does the job.
Posted: 08 Nov 2012, 20:09
by mummywebb
bms;58332 wrote:In the box of paper, the printing side is face up. If your image transferred fine onto HTV (don't know what this stands for!) then in theory it should transfer onto other products. The fabric or compressed coasters will give a matte effect when printed - try one at 200 degrees for 90 seconds and see if that does the job.
great thanks Martin I will try that tommorow.
Posted: 08 Nov 2012, 22:31
by socialgiraffe
Hi Mummywebb
To give you a rough idea take a look at the attached. I have created this in Photoshop as a representation only but will give you an idea of what to look for.
The top image shows how your image will print out when the dye sub settings have been selected and are correct.
The bottom image is how it should dye sub onto the product you are producing
Hope it helps
[ATTACH=CONFIG]1278[/ATTACH]
Posted: 09 Nov 2012, 07:12
by mummywebb
socialgiraffe;58360 wrote:Hi Mummywebb
Hope it helps
Thanks very much SocialGiraffe that was very helpful and neither my printer nor my transferred image looked like those.
I will check to make sure I'm printing on the right side of the paper, change my printer settings, and press longer and hotter and see what happens.
Thanks again for taking the time to do that.
Posted: 09 Nov 2012, 09:51
by mummywebb
Hi so I did another press this morning. I used the normal text only settings on the printer and pressed at 190c for 90secs (FYI Martin I couldn't get the heat press to go above 190c is that correct? I dont' have proper instructions for it so I'm not sure if that's right or not?)
Anyway it worked much much better - thank you for your help
Posted: 09 Nov 2012, 11:52
by WorthDoingRight
When you clamp the press and start the timer does the temperature then go above 190? A number of presses have both a lower idle temperature and then a pressing temperature. For some reason the menu item for setting the lower idle temperature often appears first when you enter the settings and you infact need to go down to the next setting in the menu to increase the maximum pressing temperature first and then go all through the menu back to the beginning to set the idle temperature again. If you do not have a manual then perhaps a photograph of the control unit may assist us in helping you set it up.
