Re: Slate with marks on it.
Posted: 05 Oct 2013, 18:17
Hi Dave
I have the thick (about 10-15mm) base pad but this is covered with a teflon sheet and then the top platen also has a teflon sheet covering it. I have always done this to protect the surfaces of the machine plus the thin teflon sheets can be easily cleaned by removing and washing. Tape the top one on the sides with lots of heat resistant tape.
Its also quicker because when pressing garments you should always cover your garment with a teflon sheet to protect the garment from marks on the platen or base pad. if they are stuck in place you do not need to.
The below is what I am referring to:
http://www.ebay.co.uk/itm/40cm-TEFLON-H ... 5898ee8925
