Old photos onto Placemats
Re: Old photos onto Placemats
PowerDriver should have come with your Printer & Inks. It will be on the SubliJetR CD.
John G
Post by John G »
RGB I think is for your monitor or screen, as in Red, Green, Blue - you should be using powerdriver to print if you have a Ricoh 7000 or a profile if using a Ricoh 5050
joconnell
Post by joconnell »
The disc I got was GelSprinter GX 7000 . This has Driver,Manual and Ulility on it. I have been using this printer for the last 9 months and everything was fine.Only today has it caused a problem. Would System Restore to a previos date help.
James
John G
Post by John G »
I think the disc you have used is for the standard drivers for your printer - for dye sub printing you need to install the powerdriver that should have come with the inks.
joconnell
Post by joconnell »
Thanks for all who offered advice on my problem. I spoke to Xpres this morning and have hopefully solved the problem which was the wrong inks I was using.I source my inks from a supplier in Scotland and have been using them for a few momths now with no problems. The last cartridges I got for black and cyan were for a Ricoh 7000 but not Sublijet which I did not notice. Subsequently when I pressed them, the inks burned giving the brown colour and bad quality. I now have to flush out the system which will take approx. half a cartridge of black and half a cartridge of cyan. Make sure your inks have a Sublijet sticker on them.
Thanks again,
James
