Ah fair enough.
Just one question , when you mention 3rd party Toners are you referring to the SunAngel ? As I believe the colour printer in the SunAngel system is standard Oki ink.
Though I stand to be corrected if I'm wrong :biggrin:
installing sunangel printers????
Re: installing sunangel printers????
The white inks in the sunangel system are not OKI inks.KathG;100409 wrote:Ah fair enough.
I imagine the normal (CMYK) colours are OKI why would they change them? . They do have some "neon" toners and these are not OKI Toners
Hi again, the reason I asked was as the CMYK toner in the OKI 321dn from SunAngel is the standard OKi toner, then as this printer is on The Magic Touch compatibility chart I should be able to use your TTC 3.1 and OMB 5.3 Papers?
Thanks though for your input, all information is good.
Now I just need a lottery win and I would be ordering Your OKI C711WT
Cheers
Kath
Kath
Sure the colour one will be fine. Use TTC3.1 A4R and the OBM 5.3, As many mention exit to the rear of the printer to stop scratches. Setting as per guide.
The only real downside to the 3 and 5 series is the single image unit, when that goes in one colour you have to replace the unit instead of single colours for the 6 and 7 series machines.
The fusers in the bigger machines are better but they are more expensive.
Thanks Alan, that's great information.
Might just have to take a look at your Oki C610 in the near future
Regards
Kath
Regards
Kath
Cheers
Kath
Kath
