Re: Graphtec A3 Carrier Sheet
Posted: 21 Jan 2015, 10:14
by gstk
I dont use it very often but mine is about knackered - its got about as much sticky as my tongue. Cheapest I have seen is Magictouch at £24.00 Seems a lot of money for what it is but then I am tight. Anyone know any cheaper?
Thanks in advance
Posted: 21 Jan 2015, 10:40
by NASH
i tape my vinyl to the carrier sheet at each corner and down the middle on each side, or even sometimes i don`t even use the carrier sheet.
Or try double sided tape
Posted: 21 Jan 2015, 13:55
by bms
gstk;96680 wrote:I dont use it very often but mine is about knackered - its got about as much sticky as my tongue. Cheapest I have seen is Magictouch at £24.00 Seems a lot of money for what it is but then I am tight. Anyone know any cheaper?
Thanks in advance
Try spraying the surface with something like surface mount to get some adhension back on to the carrier sheet.
Posted: 21 Jan 2015, 21:12
I bought one off eBay a while back, not original but did the job perfectly well and a lot cheaper
Posted: 21 Jan 2015, 22:19
by malfunction
I refresh mine with a spray on repositionable adhesive, I think it's called stick and spray without checking. The Range sell it for about a fiver. just put a strip of masking tape on each side of the sheet to protect the area where the rollers run and give it a light spray.
Posted: 25 Jan 2015, 09:38
by gstk
Excellent ideas will try. Thanks guys
