Re: Help with editing mug images in corel draw x7
Posted: 30 Apr 2015, 16:07
by Reading-Print
Hi there,
I am new to sublimation business and the other day I bought over 800 ready to edit and print mug images. Some of the images you can add your own text to like happy birthday ones you can add the persons name or age. I have corel draw x7 installed on the work laptop when I add the image to the workspace and go to edit text that option is not available. The files for the images are in jpg format Please could someone help me
Regards
Damian
Posted: 30 Apr 2015, 16:32
by logobear
you cannot edit text in a j-peg file.
any text in a j-peg has been converted into a raster (picture) format.
You need to use the .cdr or other text editable file types
Posted: 30 Apr 2015, 16:46
by Reading-Print
Hi there Logobear,
Thank you for your reply, I bought the images from a seller on ebay so they are on a dvd would I be able to convert the jpg files back?
Posted: 30 Apr 2015, 17:07
by logobear
No
any other file types?
Posted: 30 Apr 2015, 17:20
by Reading-Print
On the dvd are these files
Final Jpeg Mugs - all images are jpeg
Final Psd Mugs - all images are psd
Fonts - all fonts are ttf
Latte Mug Templates - all images are png and jpeg
None Edit Mugs Final - all images are jpeg
Posted: 30 Apr 2015, 17:44
by Reading-Print
so what file types do I need to buy to do mugs, phone cases ect?
Posted: 30 Apr 2015, 17:54
by KathG
If the files are in PSD there's a good chance the elements will be in layers which would allow you to edit/change font.
You should be able to import the PSD files into CorelDraw
Kath
Posted: 30 Apr 2015, 18:01
by KathG
Hi Again, just did a quick attempt at opening one of my PSD files in CorelDraw7. Did not work out great. Do you have Photoshop or Photoshop Elements as they will work for your PSD files.
Kath
Posted: 30 Apr 2015, 18:51
by AlanD
KathG;100910 wrote:Hi Again, just did a quick attempt at opening one of my PSD files in CorelDraw7. Did not work out great. Do you have Photoshop or Photoshop Elements as they will work for your PSD files.
Kath
Generally speaking it is better to IMPORT files into Draw using the relevant import filter. OPEN is best used for CDR files only, other formats may well open but are more reliable when imported. PSD may be editable but I find it is best to do the text in Draw as text manipulation is more flexible. JPG is fine (providing resolution is high enough) but for rescaleable objects and crisp prints you can't beat vector, obviously that doesn't apply to photographs.
Posted: 30 Apr 2015, 19:04
by KathG
Hi Alan
I agree. I did use import but mistakenly typed open :wink: .
Kath
