Re: xpres basic mug question
Posted: 25 Aug 2010, 18:59
by Steve
I have got my printer setup epson 1400 ink and profile seems to be ok, the next question is I am using xpres basic mugs and would like to know if any one know the temperature and the time i need to use for these mugs.
Link to the mugs here, they are the top ones "Coated Ceramic Mugs - XP5013"
[url="http://www.xpres.co.uk/shoppingcart/aca ... amics.html]http://www.xpres.co.uk/shoppingcart/aca ... amics.html[/url]
Thanks in eager anticipation
Steve
Posted: 25 Aug 2010, 19:21
by Kaz
180-185 degrees for 180 seconds, once your press has reached the right temp.
Best thing to do is heat the press with a mug in, and once it reaches desired temp, swap with ready to go mug, the temp will drop slightly until it reaches the 180 degrees again, and your 180 secs start from there.
Good luck :D
Posted: 25 Aug 2010, 19:25
by Steve
Thank you Fingers/Legs/ears and anything else crossed
Steve
