Dummy Iphone 5 uk seller?
3D Sublimation
adamctid
Re: Dummy Iphone 5 uk seller?
Post by adamctid »
does anyone know where I can get a dummy IPhone 5 1:1 scale from the UK please?
I need it pretty sharpish and the only ones I can find are from China.
waynewes
Post by waynewes »
This is a UK seller in Portsmouth, I used him before and was quite quick:
http://www.ebay.co.uk/itm/331574210439? ... EBIDX%3AIT
If the link doesn't work his shop name is bgadepot
adamctid
Post by adamctid »
cheers mate, it's the actual fake phone I'm looking for though, for using once they're out of the machine.
waynewes
Post by waynewes »
Oh, sorry, I didn't even realise that was a thing, what would you use that for? (I just mean what type of situations)?
adamctid
Post by adamctid »
no probs pal. I use them to when I take them out to ensure the shaping is correct, I pop it on and into cold water, I have problems with the iPhone 5 cases they tend to bend up at the corners and not fit properly, all other cases work perfectly.
adamctid
Post by adamctid »
How do you cool them mate?
ArtyGamer
Post by ArtyGamer »
If your i5 cases are bending at the corners, there's something wrong with your cases. Who manufactured them? I've gone through maybe 350 of the 500 that I bought and haven't had a single problem with them; it's the ones with a large Bestsub 'B' embossed on the inside. All perfect, very sturdy and not flexible in the slightest.
jonna
Post by jonna »
Could you not use a mould that they use in the vacuum presses?
http://www.longforte.com/3d-mould-for-iphone-5
ArtyGamer
Post by ArtyGamer »
My guess is that the jigs are already being used to create the cases, so they'd be far too hot to use for cooling purposes. There's a size difference, too. The jigs are made to fit cold cases but they change size when they're heated in the press, and likely wouldn't fit on a phone if you used the jig to cool the case. That said, I haven't tried, as I've always used dummy phones for cooling.
adamctid
Post by adamctid »
I got them from a Chinese supplier, all the others from them have been fine, it's when they are cooling they contract which causes the size problem. where did you get yours from please Arty?
